Heya;
i know absolutely nothing about boost controllers. i hope; by the time i've had a bit of a read i'll be a little more enlightened; but additonally; i need reccomendations on which is best suited for what i
will use it for.
the cars a 34 gtt S2;
I've been speaking with people at RE customs in vic; the plan is nothing ridiculous; i'm aiming for that stage 1 upgrade as its called; that squeezes the most out of the stock parts without costing a fortune.
*air intake: done
*free flow exhaust: done soon
*boost control: planning stage
I've read the info on what i should be expecting to get out of the stock bits; so looks like i'll be dialed up to about 10 psi and left there. from my understanding that's barely using them.
The mechanic at RE was saying when they do the install; they'll give it two settings; one for the stock (and reliable :rolleyes:) factory setting of 7psi and the other their upgraded settings.
So that would be the only requirement of the controller. it would need to have the ability to switch between two settings and uuuh thats about it. i don't really want to play with the thing.
a mate of mine is offering to sell me his used gizzmo electronic controller with solenoid for around 200 bucks.
i know so little about the thing i'm in danger of jumping into a bad deal. since the whole thing hinges around this solenoid; is it a bad idea to buy a used one? would the gizzmo be appropriate for what i need?
Any advice; much appreciated.
Gready profic type II. A little hard to set up if you are a first timer but nothing your tuner cant do. Great quality, not overly expensive and probally one of the better ones on the market! Mine hasn't givin me any trubble but im only in my first stages of modifying the engine.
For a basic set up like your doing there is no need to spend much cash on boost control
get one of these.....
http://www.skylinesaustralia.com/forums/topic/73375-i-found-a-good-cheap-boost-controller-for-22/page__hl__loose
if you just want one setting, then change the actuator spring
no need for a controller at all
also
running dual stage boost or "high" and "low" just allows for failures and over-boosting
ie if you cant safely run "high" then why run it at all?
run and set the car for the highest safe setting and control the car with your right foot
All the options above are possible but for a good ebc that will see you through future mods a gizzmo is good value, $275 delivered off ebay every day of the week!
buy ur mates gizzmo boost controller, it's good
Turbotech for cheap bang for your buck or Gizzmo if you want electronic controller (also acts as a boost gauge I think, so no need to buy a separate gauge).
It is a boost gauge but does not show vacum if that matters.
hks and greddy boost controllers are always going to be popular and preform well.
currently I've been using Ark Advanced Boost Controller and have to admit i love the thing, had to have a good read of the manual for adjustment - but after that it was straight forward
was waiting for someone to say a turbo tech they are brilliant 30bucks from ebay and if your not pushing for to much power they are great just bleed 2-3psi out of it and you should be fine.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
