This is my current setup on my RB20DET R32GTS-t:
GT2530 turbo
3inch exhaust turbo back
FMIC
14psi w/ bleeder
Pod filter w/ partition & CAI
500HP intank fuel pump
Oil catch can
I currently have a dead stock ECU and my car is running pretty rich (std injectors as well), and i want to know what my best option would be with getting some better management. This is what i want to achieve:
- Disable speed cut
- Disable boost cut (or alter it)
- Optimise A/F ratios for maximum power.
I won't really be modifying my car anymore after this.
I have been looking at getting a chip put in my ECU via Chiptorque. The actual chip apparently will give me what i am after and they will make it to suit my current mods using a dyno. I am looking at around $900 for this all up.
Power FC is another option but seeing as i won't be doing any more mods, i think it would be a waste of money....that's even if i could get hold of one.
Are there any other options that i could explore?
Any help is apprciated, as i don't want to make a decision without a bit of advice.
Scott
https://www.sau.com.au/forums/topic/36448-r32-next-mod-ecu-options/
i want to know too. i've got exactly the same mods plus safc, ebc and rising rate fpr. i'm not a big fan of the chiptorque chips, but i know you can get remaps and tuning done for about $600 elsewhere on the coast or brissy. i'm thinking of getting a FCD, cut wire to remove speed limiter, and safc tune on dyno. alternatively i can get a boost cut, fuel cut and raised rev limit raised chip for $200, then get safc dyno tuned.
Can get ya an Apex Engineering (APEXi's custom dept) Power FC for the RB20DET. Ultra tunable and most shops can do it on the fly.
Or I can give you a book with all the different fuel maps you need, but its in japanese.
If your going to be runnng the HKS 2530, then you may want to consider a bigger AFM. This will add a few $$$ plus make the re-map a little more difficult, though still possible.
Whilst the remap is cheaper, at close to $1000 i would stretch to money to a PFc, you get a great live readout of engine parameters, more flexible tuning albeit with a handcontroller and can be bought at the moment for $1100.
If you ever want to sell the car, then you can sell the PFC, and re-install the std ECU, along with the std turbo setup.
That said im running a re-mapped ECU, and will be getting it tuned again with new cam gears/maybe new cams, but im expecting to only pay about $300-400 all up for the tune
I have never dealt with Chiptorque before. Any reasons why you don't think it's a good idea. PM me if you want. Who else has experience with remapping r32 ecu's around Bris, GC? Since i don't have an safc, i won't be doing what you are thinking of doing, as it will cost me way too much and would be better off going full management. fuel cut defenders and safc's aren't cheap. When are you hitting boost cut/fuel cut? And that $200 chip you speak of, is that one that was remapped in another car to different mods? I was think down this track...but how wrong can you go? Like a remapped ecu on a different 32 with similar mods. But what are my chances of finding one that was setup for 2530...lol
I really don't want to mod the car anymore after this....as the next step would have been cams z32 afm....but where does it come to an end...lol
PowerFC would have been the ultimate option, but it all adds up. Say $1100 for it, 400-500 for hand controller....and then tuning! eeek!
Was your remap done on your cars ECU? How much did you gain from it? And what mods do you have?
Thanks for the help guys.
Scott
erm.. yer generally it ends up ending with a rb25 donk or in my case a rb30 donk.
Whats the power curve like? no dips etc? I've heard of good results by just fitting a fuel cut defender. That one that was in the zoom mag that good defected (James from D1) he made some where up around the 230rwkw mark with a fuel cut defender.
Hi Scott, I can tell what a good tuner can achieve by remapping a standard R32 ECU via an on line chip upgrade. But I can't tell you who is a good chip tuner in bananaland. So I would be wasting my time.
My suggestion would be to find your local chiptorque or fueltronics agent, get a written guarantee of results out of them. Tell them you will tell 100 other R32 owners in Joeterritory how great they are if they do a good job on your car. Then get 20 other guys to ring up and say they are waiting on your results. I will bet you that you get a good tune. An average tuner takes longer, but can still get it right, you just have to make him want to spend the extra time.
If you want I will be one of the 20.
I won't bad mouth Chiptorque, i've just seen some less than impressive improvements/power figures for a fair bit of money that it costs. $600 is about my limit for a remap and tune, you'd have to seriously think about spending the extra for an aftermarket ecu above that. That said, they do have a very good reputation and maybe i just need to talk to some more people with tuning by them.
Someone to talk to would be Matthew Spry (0411 340 033 ). He doesn't get a lot of press because he doesn't work for a workshop, he has his own dyno in Molendinar and only does tuning including a lot of the high powered cars on the coast. Gavin Wood also does ecu remaps now and while they're not cheap, his results always impress. The $200 chip only removes boost/speed/rev limit, its not for fuel and timing maps.
Joel i am running into the 10s with the AFR's. My power curve isn't that exciting as you can imagine. It's running the richest at around 5-500rpm which is where the meat of my power should be.
Thanks for the tip Sydneykid...i'll let you know what i decide. I am just making sure to explore all my options before making the plunge.
Neil, thanks for the contacts. Does this Matt do remapping...and how much rb experience does he have. How does Gavin do remaps without using the aid of rollers?
Cheers,
Scott
I remember at least 2 years ago when GTR-Ben was called GTS4-Ben over on SDU.
he said .. If its running rich pump more boost in to it.. lol. :)
If you arn't looking at any more mods then a fuel cut defender might do the trick, providing its all checked out on a dyno while you pump the boost in to it. Sure it won't give you the perfect power curve but it will make more power providing there is a good amount of fueling head room towards the end of the rev range.
I'm not sure if Matt does remaps. Gavin does his remap tuning on the street and Dyson Rotary's dyno.
I may have an SAFC available in the next week if you're interested? There's also a FCD for sale on here and 1 on boostcruising (see post by pink gt) both at about $50. That would mean only about $370 plus probably 1 hours tuning ($85-125) if you wanted to go that way. I'm think i might have to go a standalone ecu since it looks like i need my loom redone anyway and i wouldn't mind bigger injectors. I think i may have to sell a kidney to afford it though...
go for the power fc there is no need to buy the hand controller if someone else is tuning it. If u aren't gonna b modding more then you will only be paying for tuning once. The only problem is you will need to get it tuned with someone who has the apexi excel software, i'm from melb and dunno QLD places. either that or get the hand controller and tune yourself, but u can't see much of the map resolution, but with apexi excel software you can see the whole map and you will get the best results this way.
Try www.fc-datalogit.co.nz
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
