R33 gtr front seats retrimmed in grey leather (jus to refreshen) vgc $650 pair
r33 gtst high flowed turbo, ball bearing and steel wheeled, pulled 270kw @17psi eith more to go if I had more mods. Has lines and internal gate attached. $650
r33gtr front lip FRP in alright condition can use some attention. Minor repair previously done which can be sanded down but barely noticeable on car $250
gteddy profec a, solenoid clicks a little but that's normal according to manufacturers, free greedy tubo timer, will sit in ashtray area perfectly $300
apexi pen turbo timer black 70
GC8 mild steel catback with MRT muffler 500
Billion VFC water temp and voltag gauge with all wiring 150
Oil temp and oil pressure gauges black face white lit with all wirin and sensors 120 pair
Dildo knobsx4 20ea
more to add, pics coming, pickup livrpool or happy to post at ur expense
Mines ecu r33 s1 250rwkw with pod full exhaust cams highflow turbo fmic @14psi $350
Blitz pod 50
R33 pink afm 100
4x50mm gauge holder plate 20
Power fc with HC suit late model SR serial SR17 $800
NOTE: can't remember where I put the oil temp and press sensors so can take gauges alone fr $60 or wait til I find it. (press I know where it is)
All pms replied
I'm posting up on my iPhone and it's not exactly the easiest thing to use regarding uploadin pics from the phone. If the layout was like tapatalk then would be much easier.
Warlord- I did send pm's to you with pics of the cage :S I didn't reply on the seats cos someone was already in the talks to come inspect so I didn't want to undercut anyone, for that I apologise
Turbo already posted out so definitely sold
ok thats cool but i never got those pics in the car of the cage.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
