still have heaps:
-air con fan
-dash
-cluster surround trim
-cluster 141xxxkm's.
-ignition, door locks
-handbrake boot with centre console compartment
-tail lights
-headlights
-floor carpet
-doors
-door cards
-door handles
-mirrors
-hicas lock bar
-all kinds of seals, trims and rubbers
-boot lid
-stock shocks and springs
ask me for anything else, i might have it
0408391831
  • Replies 51
-engine crossmember
-dash
-door steps
-wipers
-cluster surround
-boot seal
SOLD!
still got lots of little interior parts, headlights, door cards, doors, mirrors
make an offer
  • 7 months later...
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
