Hey guys, I've noticed abit of oil around the drivers side of the engine bay and it appears that it is coming out of where my dip stick goes in as the dip stick is popped out everytime I check, I am going to order a new dip stick because of heard that the seal can be rooted, what are the other causes of this and how bad can the problems be?
Cheers in advance - trent
https://www.sau.com.au/forums/topic/365171-oil-shooting-out-of-dip-stick/
Yeah, a catch can that hasn't been installed properly can cause abnormal crankcase pressures dude. There's a massive guide somewhere on this forum about all the possible ways to correctly plumb in a catch can. Can't remember the thread name but just search "oil catch can" and it'll find something.
If you want to track down a new dip stick as well, go to Jerry again. He got back from Japan last week. I remember him having a crapload of RB dipsticks laying around his workshop.
Edited by GT32
Sweet dude I'll give him a call, he posts his stuff doesn't he? It's just a pain in the arse driving to epping from the east, I'll check out another place I found this week aswell.
To be clear, the reason the crank is pressurising is that blow-by is getting past the rings - but, that can happen even on a relatively OK motor. The fact that it's pressurising the crank to the point of the dipstick popping out may be a cause for concern.
The pcv valve (positive crank case ventilation valve) is intended to vent the crank pressure. If the valve is gunked up, it won't be doing that job properly. Not hard to remove and clean, check operation.
An incorrectly plumbed catch can will stop the thing venting if it's effectively plumbed in a loop. Basically you want to leave the factory route between the PCV valve and the inlet tract the same, and just intercept it at some point with a catch can. The basic route should not be altered.
Cheers dorifticon, that explains alot, because I'm not that mechanically minded but pretty handy with tools how would I go about cleaning the pcv valve? A picture of an rb20 where the valve is would be awesome, I will also post a pic of the current catch can setup,
Cheers
ok here are a few pix and a diagram i drew
alot of the oil in the engine bay can be explained by the outlet (which cant be seen in the ppic because it is at the bottom faceing the strut) on the catch can, but some of the spray appears to be from where the dip stick is
Edited by TJR32GTS-T
2 issues here:
1. Yeah that catch can isn't plumbed correctly ...but it's more just a case of it being 50% effective (at best) rather than causing a pressure build up. The two cam covers should be connected directly by a hose and the catch can plumbed into the line going out the right hand side of the diagram - between right hand side cam cover and intake pipe.
2. Unless.....the PCV valve isn't working. See the hose coming from the manifold and onto the T-piece? Is the 1-way valve working to stop manifold pressure from entering the cam cover at the t-piece.
Sorry I only know how the R33 one works (which has a 1-way valve) at the cam cover.
ohhh and where does that right-hand side pipe end up? hopefully in the intake before the turbo. ie stock location.
Edited by simpletool
Ok so if there was a hose bridging the 2 cam covers would it be efficient? They are kinda technically bridged but through the catch can. Also what do u make of the 3rd outlet on the catch can? I would imagine the catch can wouldn't fill because the outlet is at the bottom(see diagram) other setups I have seen have that outlet up the top with some sort of filter.
Also I'm not sure how to check the pcv valve?
Thanks for your input :)
There should be not outlet on the catch-can, other than the drain plug. That drain plug has the plug in it....right? Otherwise you are drawing in unmetered air through the catch can.
Anyway, I've put some details in the photo. post-23086-0-67816600-1306199969_thumb.jpg
Dont' mind my other comments, I got a bit carried away.
The PCV valve should only allow air to flow INTO the manifold, but not from the manifold and into the cam cover. You might have to check other threads for the RB20 PCV valve and where it is. you can test by blowing into it each way,
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
