Hey guys, I've noticed abit of oil around the drivers side of the engine bay and it appears that it is coming out of where my dip stick goes in as the dip stick is popped out everytime I check, I am going to order a new dip stick because of heard that the seal can be rooted, what are the other causes of this and how bad can the problems be?
Cheers in advance - trent
https://www.sau.com.au/forums/topic/365171-oil-shooting-out-of-dip-stick/
Yeah, a catch can that hasn't been installed properly can cause abnormal crankcase pressures dude. There's a massive guide somewhere on this forum about all the possible ways to correctly plumb in a catch can. Can't remember the thread name but just search "oil catch can" and it'll find something.
If you want to track down a new dip stick as well, go to Jerry again. He got back from Japan last week. I remember him having a crapload of RB dipsticks laying around his workshop.
Edited by GT32
Sweet dude I'll give him a call, he posts his stuff doesn't he? It's just a pain in the arse driving to epping from the east, I'll check out another place I found this week aswell.
To be clear, the reason the crank is pressurising is that blow-by is getting past the rings - but, that can happen even on a relatively OK motor. The fact that it's pressurising the crank to the point of the dipstick popping out may be a cause for concern.
The pcv valve (positive crank case ventilation valve) is intended to vent the crank pressure. If the valve is gunked up, it won't be doing that job properly. Not hard to remove and clean, check operation.
An incorrectly plumbed catch can will stop the thing venting if it's effectively plumbed in a loop. Basically you want to leave the factory route between the PCV valve and the inlet tract the same, and just intercept it at some point with a catch can. The basic route should not be altered.
Cheers dorifticon, that explains alot, because I'm not that mechanically minded but pretty handy with tools how would I go about cleaning the pcv valve? A picture of an rb20 where the valve is would be awesome, I will also post a pic of the current catch can setup,
Cheers
ok here are a few pix and a diagram i drew
alot of the oil in the engine bay can be explained by the outlet (which cant be seen in the ppic because it is at the bottom faceing the strut) on the catch can, but some of the spray appears to be from where the dip stick is
Edited by TJR32GTS-T
2 issues here:
1. Yeah that catch can isn't plumbed correctly ...but it's more just a case of it being 50% effective (at best) rather than causing a pressure build up. The two cam covers should be connected directly by a hose and the catch can plumbed into the line going out the right hand side of the diagram - between right hand side cam cover and intake pipe.
2. Unless.....the PCV valve isn't working. See the hose coming from the manifold and onto the T-piece? Is the 1-way valve working to stop manifold pressure from entering the cam cover at the t-piece.
Sorry I only know how the R33 one works (which has a 1-way valve) at the cam cover.
ohhh and where does that right-hand side pipe end up? hopefully in the intake before the turbo. ie stock location.
Edited by simpletool
Ok so if there was a hose bridging the 2 cam covers would it be efficient? They are kinda technically bridged but through the catch can. Also what do u make of the 3rd outlet on the catch can? I would imagine the catch can wouldn't fill because the outlet is at the bottom(see diagram) other setups I have seen have that outlet up the top with some sort of filter.
Also I'm not sure how to check the pcv valve?
Thanks for your input :)
There should be not outlet on the catch-can, other than the drain plug. That drain plug has the plug in it....right? Otherwise you are drawing in unmetered air through the catch can.
Anyway, I've put some details in the photo. post-23086-0-67816600-1306199969_thumb.jpg
Dont' mind my other comments, I got a bit carried away.
The PCV valve should only allow air to flow INTO the manifold, but not from the manifold and into the cam cover. You might have to check other threads for the RB20 PCV valve and where it is. you can test by blowing into it each way,
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
