  • 4 months later...
I know this isn't a car damage story, but it's a VicRoads incident all the same.
After the bushfires, the only thing that survived on my property was my steel gate & fence line. Anyhow, VicRoads decided to do some maintenance on the roadside verge a couple of weeks after the bushfires (go figure). They dropped a tree across my fence - my only surviving asset!! You can imagine my disappointment, considering we were traumatised by the fires and eager to get back on our feet again - with this careless piece of maintenance setting us back one step.
To cut a long story short - we lodged a complaint and they basically said bad luck. Initially they blamed the volunteer groups, then some other department, then we got in touch with a VicRoads representative for the bushfires. She said she'd look into it, but basically don't count on it (based some sort of legislation which I couldn't find). I felt like asking how she'd feel if I drove through ther front fence and said "bad luck, refer to the legislation".
We complained and chased the representative every second day for months and months. My wife and I took turns in hassling them. I only claimed bare minimum materials & bugger all labour. They eventually paid up after a VERY looooong time.
Hint: If you get a name, keep records, and the slightest hint of compensation - you gotta play the game and be persistent, really persistent.
And in the long run if its not a large sum of money (in which case they'll never pay up anyway) is it really worth waiting 'months and months' for a payout that may or may not happen? This is the question.
It got to be a battle of principle in the end. The amount of avoidance was frustrating. We eventually got our money.
That, and the insurance company playing funny buggers just made it our job to try and recover all the money we were owed.
It can't be a battle of principles when your car is off the road. I argued with vicroads for four months with my car off the road and undriveable until I had to make the call because I needed the car back and working. It took a further 3 months of labour to fix the damn thing. Had I kept arguing or taken them to court I likely still wouldn't have anything more than a broken car in my basement.
No. Their process via notice of incident and claim is you send them a quote. They sit on their hands and think for a bit and then tell you they're not liable for any damage caused in part or wholly by road conditions. And that I quote almost verbatim. Oh...and you have to submit all of your paperwork within 30 days of the incident.
Once I got offered $3k. I said no way. Five years later and $20k of lawyer fees I got $126k. Gotta keep at em and make em pay. Federal legislation over rides any company/local government policy.
maybe in WA.. this is Vic..
but 126k and you still drive a 33? lol
It was South Australia. There is better stuff to spend that amount of money on than cars.
true, but you'd think one thing to spend it on is to update an aged car. surely..
His point still stands. The Victoria part.
damn straight. fkn victoria. the place to wee
I agree with you blokes totally about the vic laws. Just because someone has a 500 hp car doesn't mean they will hoon in it. Most cars will break the speed limit and burn rubber. It the drivers discretion entirely what the car does. What can ya do tho? Move to WA if you have to. Only difference here is that you don't get hassled by cops. No doubt you'd get busted for being a hoon but that isn't the point.
You'd be surprised what people will do when they are starting to think that they will lose in court and have to pay your lawyers bill. They usually give in. It just takes time and commitment. And make sure you have a legally winable case or you will lose your money and time. A lawyer will tell you if you can win for a fee. At worst you lose a few hundred dollars and fix your own car. Eh what can I say? It sucks to live in vic.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
