Looks awesome Nick! Did you do the graphics for it? (I am assuming you did).
Unfortunately not,
I did all the initial art work with different sponsors (Rocking Angel which is our Bourbon).
It only got the call up to allow it to run at the last minute so they got the vinyl cutter to put something on, especially after they did the whole chrome wrap on the car
  • Replies 3.6k
Posted Images
Any blokes who can help with some lifting and positioning of floor frames at my place say 2pm tomorrow in the Mansfield Park area? There's beer involved.
3 weekends now getting family/friends to come around and help with no results. Ready just to lift the f**king things myself and do my back in.
Got heart attack?
Soon!!!
-D
PS Whiplash mines the wild "t.u.r.key", lucky and little creatures. Rest are the other lads ;)
Ps Spam filter is wak.
EDIT - Heres the recipe btw http://www.bbqaddicts.com/blog/recipes/bacon-explosion/
same colour as my mates one.........surely one of yas would remember it........even if you do remember it for the wrong (transformers sticker on bootlid that he didnt put there LOL) reasons
does need a good home, and has lotsa goodies. also needs to do a good hillsie
PM sent regarding TME
Nice fridge there Ben .... sorry I couldn't make it - a leave pass from the missus 2 weekends in a row is tough enough (was in Melb last weekend), without throwing Kadina in a couple of weekends time in the mix too.
The Guiness must be Pat's I am guessing?
For any of the Northies, I am again workig on the 35 today, so if anyone wants to come help/watch/drink/talk shit then you are welcome. If you know where I am live, you are invited. Thanks for Brad and Pete's help yesterday! Got the front suspension changed, front adjustable sway bar on and braided brake lines done and bled. Today is the rear end. hopefully will have time to fit the new rear bumper bar too.
Thanks for the kind words bud but I only recall offering you abuse....not help :P
..........and yes, that car is def a favorite of mine............if only I had the cash :(
And yes I was going to say what did Pete do to help? But then I remembered he pumped the brakes.
Are you going to be around wednesday afternoon. Ill come and hook the shed up before tea.
David and Pat both brough guinness - fridge is happily empty now!!
-D
I'll make time for you bud.........I'll give you a call later.
Yes, my email notifications are not working also Steve .... I assume something is wrong with the system. I thought SAU had gone offline for a day or so there given my lack of email notifications ....
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
