I dont see what the problem is with fake carbon, it still looks good, and if you wanna go and buy the expensive real stuff to save weight, youll know deep down inside your saving those few extra kilos.
  • Replies 3.6k
Posted Images
It was designed to be watched quickly though - didn't want to drag things on. It's not perfect, there's a couple things I would of liked changed but yeah...
I think its a pretty good job. Bit of plain information, bit of comedy (needed benny-hill chase type music when the IronChef runs after Miss.Fine); keep up the good work I say!
Yeah will defs go with that one
good price and looks tricks
no worries. also after looking at the link i posted theyre not the n1 ones i was thinking of
just jap sell those, $100 more so not really worth it
http://www.justjap.com/store/product.php?productid=17336&cat=&page=1
its not to save weight most of the time its just to have the real thing. next theyll be using the chrome wrap becuase its cheaper than chrome. doesnt bother me, gives those with the real deal something to chuckle about
Its good, I like it.
except for the random drifting part which doesnt fit in to the title
When is it your turn to co-host it?
What do you own that is 'genuine' carbon?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
