  • Replies 3.6k
Posted Images
anyone feel like mc donalds
quad core ;)
and my mate attempting to eat IT
I had to make one for a customer a few weeks back now....the biggest I have had to make so far is a cheese burger with 18 pieces of meat and cheese...was huge.
That double double pounder is bush league @ $10. I often get 2 McDoubles and put all the patties in one bun - great value for $4. Obviously for $10 you could get 5 x McDoubles (10 patties) and eat it - would be a ton more meat than a pound :)
im getting sick just thinking about that
hmm so for $10 i could have a 4 patty burger and have change to buy a Heffe Bier
Actually you are wrong there. The meat is in a ratio to 1 pound.
Cheese burgers, Mc Doubles (Double Beef N' Cheese), Double Beef and Bacon, Hamburger, and Big Macs use 10/1 or 10 patties to 1 pound
Quarter Pounders use 4/1 or 4 patties to 1 pound
Angus use 3/1 or 3 patties to 1 pound
So having 10 cheese burger patties is the same as 4 quarter pounder patties, ie 1 pound.
The number of stolen imports this week is really alarming to me. Im sure I speak for alot of people when I say the authorities need to step up their efforts to catch these people. We are relying on word of mouth to stay updated on the stolen cars, and if these people are caught by the police, we take one more step towards eliminating this problem.
Although if the people are caught by the people whose property they have blatantly stolen and abused, the repercussions would be alot worse than grand theft auto charges.
If the authorities are reading this post, please take this seriously and do something about it. It seems there is an organized regime of the same people targeting imports and driving the cars around to go steal other ones. Something like a bait could be simple enough to catch these people.
The reckless manner that these cars would be getting driven in should be enough of a sign to police to act on the matter.
I have personally run out into the middle of the street at 1am in my jocks brandishing a pool cue and half a mongrel when I thought my missus' camry was being stolen.
Does anyone know / use a courier they can recommend to get an engine delivered to Adelaide?
I can pickup at any depot this end, but would be nice if the courier could go get it and maybe stick it on a pallet that end to save me some hassle.
Any recommendations would be great. Need it from Vic to Adel if that helps
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
