  • Replies 3.6k
Posted Images
Considering making a gif thread Steve, seeing as people complain that it takes so long to open the Wasteland with a page full of them. I remember when the wasteland was full of pics, videos and gifs!! But saying that, theres enough threads popping up weekly with stolen cars and misplaced for sale items, we probably dont need another thread.
Yeah but 2mb avatars seem fine :/
Make a thread bugger it or just post here
I've only seen one person complaining. I go through the wasteland a lot with my phone, page full of gifs only adds 30 seconds, even on Vodafone.
yes its me lol
I like the gifs just not with 1 bar of signal on safari. firefox much better. (optard shares towers/switches with voodophone so both suck), hell all phone companys suck in general
my 4s will be here friday so I'll see it the Dual antenna fixes anything, doubt it maybe if I jam a coat hanger in the headphone port and put tinfoil balls on that ? like old tv antennas.haha
optard confirmed the network is overloaded down here, galaxy S was worse then the iphone signal and ate the battery faster when they shipped me a brand new test one
maybe I should use this kit
just came back from a wheel alignment and they told me I need a 'camber kit'.
After some quick googling, seems like whiteline offers something called a camber kit :P out of curiousity, what does this include?
Also, any suggestions where I could pick this stuff up?
Useless. the adjustment they offer is almost non existent. Just head down to JIS and buy a set of adjustable camber arms. While you're at it, get some toe rods too.
Problem solved.
guess optard reads my threads, the network engineeer is in my driveway now with a truck full of antenna location test gear, quick hide..lol
funny when I speak face to face they're all from Norway (ex nokia staff maybe ??) second time now both guys from norway..haha odd
best thing is , I dropped a call while standing in front of him,,haha classic
Edited by Carbon 34
the whiteline camber kit when using both bushes can remove -.75 camber. with arms to can reduce up to -3. alot more adjustment for a bit more money, and in the long run will be better than forking out for tyres all the time
just random build threads im finding on the net. Usually Amercian stuff. Tempted to get a tig welder myself and just teach myself how to weld. Its a good thing to be able to do.
Nice welds, they call it a roll of dimes in usa. cause it looks like a roll laid out like a deck of cards. DOH.
TIGS and GAS MIGS can weld that nice depending on material . I have a unused mig if you want to practice sometime..lol
Pipes are harder you have to be able to spin it nonstop while welding.or you get stop, start marks not as pretty ..lol
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
