  • Replies 3.6k
Posted Images
31 days since I got off the medication; I feel pretty awesome :)
Havent had one negative thought enter my head since getting off the Fentanyl.
Really looking forward to Medical Radiation Science studies at UniSA next year, 4years of hard work ahead but Im quietly confident Ive got what it takes ;)
Congratulations man - it really sounds like you're heading in the right direction.
Lols...
AK47, AR15, HK P90, Uzi, Barret M82A2, Walther PPK, Beretta M92F, Soviet RPG, Spud Gun, ? Car, Flintlock pistol, Lever action remington...
Sad. I know those all from memory but not the car
-D
Wow @ brake setup.
Jenna thanks very much, I feel awesome (mentally, knees a lil'bit sore but using a cream called ExitPain which I'm finding particularly helpful). I hope your back isn't giving you too much grief. If so try the cream I mentioned; available from chemists or health food stores.
Studying daily as I'm trying to take in as much as possible prior to uni next year. Its all coming along, first time in a long time I've felt like I've got something great ahead of me.... & Its mine for the taking. =D
anyone know the vacume hose setup for standard boost solenoid on a r34 neo is?
From looking around for a while i think it goes something like this:
Intake (air intake pipe) to a T piece, one end to the bottom of the solenoid and the other to the turbo valve?
Intercooler pipe to the top of the solenoid?
Anyone confirm this is correct?
Also i have an after market turbo (hypergear atr43 550hp) will take out the manual boost controller and using the stock solenoid (for defect sake) be ok?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
