  • Replies 3.6k
Posted Images
So apparently my hotmail account has been blocked....the email account to send the recovery code to has been shutdown for years, go and try to recover the account and they want passwords and bank card details?!?!?!?!? sound dodgy??
2 things hotmail would never ask for is your passwords or bank details
I would disregard the email, but if your totally worried a little test dont click any links in that actual email but open your browser and go to hotmail.com and login should work fine
I got the same 2 emails, there dodgy , they ask for info MSN wouldnt ask for ever
phishing scam
Shaft play?
do a video with the engine not your drivers seat..lol that would help unless it only happens on "loaded" boost ?
does it happen on a cold engine and hot ?
take a vacuum hose from house vacuum and put it one end on your ear, the other on the suss part you can hear the play,(dont melt the hose on the hot turbo or stick it in the fan..lol ) one thing to check is the valve train, too much clearance on the rocker or failing lifter. my r34 has solid lifters on series 2 neo motors and they make the same noise when out of spec .
if its the valve train hold it on the rocker cover and give it some throttle , the noise will jump out and be loud thru the hose. you can narrow it down to the exact location with it. unless you have a mechanics stethascope ?
How did you find that out boof through an email in your junk mail folder then click a link to reset your password?
All good problem sorted, was 3/4 asleep trying to sort that out...As soon as i logged in it told me the account was blocked and the email address that was in there to forward a new password onto has been non exsistent for about 5 years now...Got a new password and logged in ok :) Cheers anyways!!
yeah only happens when i engage my boost controller :/
and yeah only on loaded boost
i can notice when the boost increases
happens nearly most of the time
sometimes not :/
look at the video and listen really hard at 0:20 you will here it faint tickticktickticktick noise during boost
Mount your solenoid with rubber washers or a long bolt and a bit of rubber hose
PS: anyone with a R32 GT-R?
Got these for sale
http://www.skylinesaustralia.com/forums/topic/381669-r32-gt-r-air-diversion-panels-2x/
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
