  • Replies 69
Matt, Nightcrawler has video of that last burnout of yours, along with a couple of runs if you're interested. I'm a pretty shitty photographer though, so some are better than others.
Bit more smoke will get those 540s nice and sticky. You can hear you breaking traction at every gear change in one of the vids!
Yep mate, I'm VERY keen to have a look at the vid's! Thanks for filming me :D Andy, when can I drop 'round for a look? I'd be happy for them to be posted up, if that's possible?
I agree with you Dean. I'd say the Fullboost site doesn't take into account.... shall we say... local road registered car "issues" that occur in SA (Adelaide). Whereas Mark from Pulsar Parts is only too well aware.
Sam (MiTSiCHiCK), I'm guessing you're talking about me? If so... thanks :rofl:
Andy, I can come round later tonight, if that's ok? PM me your number (have been meaning to get it for a while anyway) and I'll ring you later.
Thanks mate :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
