This is a ford Barra engine sump that is almost done.
Its using the channel type system and done for a 6 stage pump obviuosly.
There is dividers inside the channel which is something not always done. Dividers try to eqalise the oil distribution when you brake hard or accelerate. The oil will still run to the front or rear of the pan. With a long sump such as this they do help. The oil can still roll over the top of the divider but its still better than nothing
The width of the channel is critical.
The channel is slightly offset to one side and the whole sump tapers into the channel. Ill keep the factory ford windage trays with this sump as they are pretty good. It has an alloy mesh "filter" inside the channel too.
As i am in the stages of gathering info for building my engine, my question to you guys is:
For a car that will be 70% street and 30% track, will it be worth me going for a dry sump setup?? Engine will be built for response not power
Or stick with a well sorted wet sump setup, which has been discussed already in these forums
Thanks
Nick
Nick it really depends on your budget.
If you an afford to do a dry sump properly then go for it even for a road going car.
When I do a regoed streeter I usually fabricate a custom tank to sit inside the wheel arch instead of a boot mounted tank. Keeps fumes out of the interior and also keeps plbing costs to a minimum.
I rather spend the extra cash and know i can safely push the engine when i need to, but in saying that i have only started doing the research on it and i am watching this topic closely.
Thank you for the time and the info
Do you have a set of baffles in the tank Brad? What capacity is the tank?
Looking at the D.E. or Verdi pump with an air/oil separator the design of the tank can be a lot simpler which owes itself to a custom built tank that can be made to fit out of the way somewhere. As long as there a some baffles to slop the oil sloshing around then that is fine.
Shoot me your details Brad via email and will get it sorted! :)
  • Like 1
The tank I normally use mike has a baffle plate similar to the Peterson round tanks ones.
Tank normally holds 8-9 litres, with excess in the sump and lines the whole things takes about 10L from empty.
The filler runs up where the washer bottle lives and still needs an under bonnet catch can to vent the tank into
Those separator pumps work really well. The Dailey I'm using one with too.
I see what you mean about keeping the channels narrow :thumbsup:
Is there anything special needed to be done to prime the oil system before starting the car in order to get the oil pressure up, or is the response from the pumps good enough ?
Some people use accumulators or electric pumps.
Normally If the car had been sitting for more than a week I'd slide the belt off and drive the oil pump with an air ratchet till it builds some pressure.
Once it's got pressure usually they are fine At start up. Works the same as ab ordinary oil pump.
That is what an engineer at Auto Verdi told me.
That's another kettle of fish all together mate.
It solves the whole smashing oil pump issue. For those who aren't aware it's possible to use a single stage external oil pump belt driven exactly the same as a multiple stage pump however instead of drawing from a remote tank it draws from the engines sump via an external pick up.
I have one sump which I've done this conversion too, it has a trust extension and now an external pick up and single stage pump.
I'll put p a few photos of that setup latter.
Is a viable option for street driven cars.
Not really no.
You could fit the pan but it won't hold enough oil to keep the engine feed.
I'm semi assembling another GTR sump currently for a mate. Im taking some photos of how it's constructed as it gets fabricated.
Guys can get an idea what goes into it that way.
I reckon someone should get onto dailey to make one of their pans with integrated manifold for RB26. bit of a challenege considering you need to incorporate diff housing too but would be a awesome piece of gear.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
