  • Replies 186
i think chubbs or cassbo posted this once.. i meant to do it in my intro-to-texi thread but forgot.. over and over. next time i see my liner is sunday though, so can't take pics before! arg
:P
That was a long next day :D
Any who, I took some pics as evil_weevil's ones have stopped working. Figure I might also do a bit of instruction while I'm at it.
Step 1.
Go to your local Autobarn / Supercheap / Repco / where ever. Take a look at what fire extinguishers they have. You are looking for 3 things
1. Over 0.9 kgs
2. AS1841.5 sticker
3. Pressure still in the "green"
4. Comes with a bracket.
Here are some pics of what I mean.
I bought my extinguisher for around $30 so I imagine that yours will cost a similar amount.
Step 2.
Pull the extinguisher out of the box and separate the bracket from the extinguisher.
Step 3.
Drill the mounting hole furthest from the bracket's latch out to at least 8mm. I drilled mine out to 9mm to give me some margin to play with when I finally mount it.
EDIT
Be careful when drilling as the drill can grab the thin metal of the bracket and force it out of your hands, usually giving a good gouge in the process. Use a vice or stand on the bracket like I did lol
Step 4.
Undo the bolt that holds down the passenger side of the rear seat.
Step 5.
Bolt bracket to rear seat mounting point.
Step 6.
Put extinguisher into bracket
Step 7.
Rip skids
Ian,
All good to turn up whenever you want through the day, and taking photos from the sidelines is fine. We have the photographers that can move about the place, and get closer shots; with their gear, we offer the service for people who want professional-type photos of their cars; they're frigging good at what they do :) I don't think you'd annoy anyone taking your own pics from the sides.
If you want to actually be a passenger in a car, you'll need ankle to wrist clothing, a helmet, and sign a short waiver that says you understand the risks of motorsports. Having said that though... It's a wide open pad with no trees or banks or anything :)
that being said, make sure you bring some church change on the day incase you feel like a feed/drink as theirs no atm's around the joint..
Thats one way to look at it, the other way is this; There is only one other location we could use for this in the whole of Sydney, it's overpriced and small. Where we go, there is a great relationship between club and venue, screamer pipes and therefore noise complaints from residents wouldnt help that cause and given this venue is booked every day of the year they dont need SAU's business so we do everything we can to not be a problem to deal with for venue management.
If it didnt have to be that way, i'd be all for it
if there still space u can enter long.
im buying one already with bracket from another member and im gonan fit it on the day.
There is a Super Cheap on richmond road blacktown (if yu get off the M4 at Blacktown reserviour road exit you'll drive past it)
There is a Super Cheap in Bella Vista Homemaker Center old windsor rd. (If you get off the M2 at seven hills you'll drive past it)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
