Hey guys,
This is one of our open-class competitor in Superlap 2011.
GT Auto Garage R32GTR
post-24739-0-49285700-1306733043_thumb.jpg post-24739-0-19513200-1306733544_thumb.jpg
Vehicle Spec
HKS 2.8L Stroker Engine (Step 1)
HKS Oil Pump
HKS 2530KAI Turbo Kit
HKS R-Type Intercooler Kit
HKS Special Full Piping Kit
HKS Oil Cooler Kit
HKS Twin Power
HKS EVC Boost Controller
HKS SSQVIII Kit
HKS 272 Camshaft & Cam Gears
HKS FCON V-Pro ECU
HKS Hipermax III Super Sport Coilover
HKS Super Turbo Muffler
OS88 6 Speed Sequential Gearbox
NISMO 1 Way Front / 1.5 Way Rear LSD
IKEYA FORMULA Roll Centre Adjuster
IKEYA FORMULA Rear Camber Adjuster
PROJECT MU Billet 6pot Front / 4pot Rear Brake Kit
VOLK TE37 Wheels
https://www.sau.com.au/forums/topic/366046-world-time-attack-2011-open-class/
Good Luck for Superlap, hope that OS88 doesn't have a G in it. Up to you but for Eastern Creek - I would recommend crossover breather from front to rear of the tapet cover!
From your content list I would hit HKS up for sponsorship
Cheers
Stuart
Hey guys,
Vehicle Spec
HKS Oil Pump
HKS Oil Cooler Kit
HKS Twin Power
HKS SSQVIII Kit
HKS FCON V-Pro ECU
VOLK TE37 Wheels
Here's top secret in 10 years track work to keep RB26's together Beleive it or not
Our full trim - rego'd R33 On A050's 1.39.464
1.40's at Superlap 2010
For the cost of your engine it is definitely worth adding.
Has worked a treat on our R32 and R33 and others.
Once again good luck, hope to get there for a look see - will miss running this year, just got too involved with Shannons Touring car
Cheers Stuart
  • 3 weeks later...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
