+1 WAS, got my 33 back from him the other week; very happy with the work (100,000 service, oil pump, harmonic balancer, air con, cam cover seals, fuel gauge reseat)
(yeah Tristan I finally got it there :P )
Hey Owen,how much did it cost. :cheers:
All up, I got the 100,000 service done (swapped belt, all the bearings and shit, water pump), oil pump as well, spark plugs, changed cam cover seals, full radiator flush, replaced air con compressor and re-gassed, fixed up the fuel gauge... changed ancillary belts too.. possibly more but i can't remember, but i supplied all parts except the ancillary belts and spark plugs, was $1600.
farkin HUGE job changing oil pump tho
  • 11 months later...
  • 3 weeks later...
+1 WAS
anyone had experiance taking there 25-30 there? ive taken my old skyline there and have allways been very happy with them
i think matt had his 25/30 there from memory? or was it a 20/30, no idea, i know there were huge problems but i don't think it was WAS problem; was with the engine
from memory though, grain of salt etc
  • 7 months later...
Take it to WAS. Go see Kon, tell him Matt and Tristan sent you.
As to the guy asking about 25/30s. He's fine with them, just as competent on them as any other motor.
Mine was there but had been built wrong, Kon helped diagnose it all, had it fixed up and I left very happy.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
