So everytime i post (using the quick reply down the bottom) in the spotted thread in the WA section and occasionally in other threads i click post and get the following error:
An Error Occurred
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
[#10151] An unknown error occurred
under that it says my post data has been saved, but it all comes up in the topic anyway?
I dont think im the only one seeing this either as there seams to be a lot of double posts in the spotted thread lately. Everything works, the post always comes up, its just weird.
https://www.sau.com.au/forums/topic/366279-error-messages-in-wa-section/
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C)
Timestamp: Tue, 31 May 2011 23:55:50 UTC
Message: Object expected
Line: 400
Char: 1
Code: 0
URI: http://www.skylinesaustralia.com/forums/forum/14-ideasfeedback-bugs/
I'm getting this error on all sections.. Loads up to before the advert block and that's it..
well after using firefox.. i found that it was waiting on www.a.tribalfusion.com and ad blocker seems to stop it.. But that is also the adverts..
Hmm I'm not getting any issues and Im using Firefox all day...
Is this just localised to the WA section or not?
Seems its larger problem?
But then I've not had one issue, usually with such problems i notice it right off on my test accounts etc :(
only happens in WA section for me and almost always the spotted thread, the other weird thing is clicking the red icon on the left to go to the last unread post doesnt work only on the spotted thread, it takes you to 2-3 posts before the end of the thread, even if 100 posts have been made since your last visit. everywhere else works perfectly in that regard for me.
i'll get over it, just found it interesting it only did it for one thread.
edit: using firefox on xp if it makes any difference
Edited by JonnoHR31
:O I'm getting the same issue, could be some how stuck on something since the forum update. Could be a wayward sig or anything else.
Will try solution - make a new thread, please start using it and let me know.
  • 4 months later...
  • 4 weeks later...
  • 1 month later...
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
