does any one have knowledge or has seen a V36 convertible here in Oz? Abit of conflicting info out there on the web.. read up on prestige motor sports.com.au no chance of importing it in here doesn't qualify with SEVS but have seen it on the raws site. So whats to go??
https://www.sau.com.au/forums/topic/366545-v36-convertible/
http://www.carsales....97730&silo=1011
there are a couple in WA by the looks of it
Yeah, there's some in WA now.
I've seen them and they look nice. But the price is still up the roof. :(
https://www.sau.com.au/forums/topic/366545-v36-convertible/#findComment-5847547
Nealy AU$80k.
You can see it in carsales link. :P
Yes I did see it in the carsales like theres 2 a pearl white, and platinum one dont know if its the same dealer. Must say VERY nice!!!!! But I think if it had red leathers that would be the icing on the cake.. Looks like I know what my next machine is gonna be :).
https://www.sau.com.au/forums/topic/366545-v36-convertible/#findComment-5848281
Is that an actual Infiniti with a RHD conversion or has somebody replaced the badges/seats/steering wheel on a 307GT? Impressive work either way as that is a great looking car.
Could be a European market car. Be interesting to see what language the dash is in.
https://www.sau.com.au/forums/topic/366545-v36-convertible/#findComment-5848583
  • 6 months later...
car is UK spec so dash is in MPH (primary) and yes the systems are in english. maps are still xeanavi / zenrin though. been talking to a few people about them.
its the head unit that I would be interested in and wouldnt take more than 10 minutes to get it out and see how many plugs it has and try it on a Jap car if the plugs match.
My v36 already has a non japanese cluster which is in Klm's
The main unit still does my head in however.
https://www.sau.com.au/forums/topic/366545-v36-convertible/#findComment-6160706
Where did you get the cluster? Pic?
https://www.sau.com.au/forums/topic/366545-v36-convertible/#findComment-6160973
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
