Mid semester break is approaching fast and I wasn't sure whether to post this here or in the general automotive section.
With 100,000kms coming up on the clock, the car is frequently getting the 'yellow check engine light' coming on, not always about one in every 10 trips and I notice nothing different about the car when it does pop on so I didn't get it checked out.
I want to go for a trip along the east side and was wondering what I need replaced and if the car would actually make it all the way there and back without blowing too many tyres and radiators etc.
This is what I had in mind for the trip:
Install a pod filter
Possibly install a cat-back exhaust (to make the engine breathe easier)
Replace timing belt
Get new tyres
Do the usual service things
Get the stock clutch checked?
Would this be sufficient to travel a few thousand KMs from Melbourne and back? Let's say I'm going to Brisbane / Sydney or maybe Adelaide.
My car is a naturally aspirated r34 skyline.
EDIT: THE CAR IS COMPLETELY 100% STOCK!
Any opinions or thoughts?
Please move this into the right section if this is in the wrong section, thanks mods!
Edited by Grey
https://www.sau.com.au/forums/topic/366793-along-the-east-coast/
Exhaust and pod aren't going to do anything to help you. If anything (and I mean with negligible effects) they are both counter productive to engine longevity.
Just get a service, do some long trip checks and stop every few hundred km (piss/food stops) to give things a rest. You'll be sweet. Cars are built to drive for a long time!
so you don't think it will break down in the middle of no where or anything like that?
It's a car mate.
It's designed to be driven. You are no more likely to breakdown than anyone else.
Just get the 100k service done. That alone will cost you more than you are thinking TBH.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
