its come time to coat my new setup, and I havnt settled on a colour scheme as yet, there are still some minor heatshields and other stuff but I want to send all the parts to get coated...
let me know what you think colour wise....
Im coating strut brace, intake plenum, cam covers, cam belt cover and intake piping
https://www.sau.com.au/forums/topic/367280-engine-bay-colour-scheme/
oh and its a silver r33 with black vented bonnet, reb brake calipers, black rims lots of CF outside & CF cooling panel. std series 2 body kit.
I choose red and blue to go with the speedflow fittings, but Im open to suggestions.
Red, do the fuel rail as well and the stut top brace bar grey or black. Then it will match the arc box.
Also don't forget the little things lime the radiator brackets etc
Edit: do the plenum and IC piping grey as well (all gloss though)
^^ This or just replace the red cam cover with Millennium Jade.
Im not sure I can powder coat the fuel rail, as it needs to fit the injectors and Im worried the coat may be too thick and make fitting harder...
I suppose I can get it re-anodised in red but that sounds expenisve....
Millenium jade, hmmm I wanted to powder coat everything though... a bit longer lasting than just painting...
you can buy fuel rails in red made out of billet.? or machine out the powercoat, or use the anodizing spary paint from VHT heat/fuel proof
stick the the same colour as your other bits, red calipers, then red for engine parts, ?
millinuim jade is overrated unless the rest of the engine is for real ? plus it matches nothing
fewer colours is better, two or so IMO
Yep metalcast ftw, have alook in my build thread dude, every thing that is red is metalcast.
If you can't find it let me know and I'll send you some pics.
You have a silver base coat than a candy on top. My covers went an orange tinge after a couple of years but the rail held up well.
Having said that Craved is currently powdercoating all my rail and covers cause it's tougher.
I've also done the runners and plazmaman and if they mask up the bits where the inj goes in It will be fine.
i've done top feed rails before, just plug them for blasting and coating and it wont get inside the machined fittings.
perhaps ask 34geeteetee for some better pics of his rail.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=342957
red metalcast over blue would go purple lol
I like this one, except I would probably leave the strut brace bits blue, and I would get rid of those horrible red radiator houses for black.
That way you would have a red black theme going with a few little bits in blue..
If it was my car however all the red/blue would be gone ,you can get black fittings, and i would coat everything else in satin or gloss black this would match the rest of your car well too :)
edit* actually even if you keep all the red/blue fitting as it is and did just the covers in satin black...Can u photoshop one of them for me, leave everything the way it is but with black covers..even if you just did the cam covers with crinkle coat black and left everything else just the way it is just polish up the metal stuff i think it would look great and only cost 20$ for a can of paint
yep thats my vote crinkle coat covers and leave the rest :D
Show off with ya fancy colours :) now your just gonna confuse him!
Do you reckon the metalcast would still purple up even with the base coat? not trying to push it cause you know I've been converted just curious.
Edit: BTW Arthur I "think" Chris can do the crinkle look powdercoating anyway
If he doesnt like the black idea
Id like to change my vote to this one though as it has the best balnace of colour, not sure why I didnt spot it before.. :unsure:
But yeah, ignore my previous posts (blabberings) this scheme with either the metalcast blue or black covers :thumbsup:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
