  • 1 month later...
http://www.amazon.com/Frost-G9-Rubber-Garage-Bottom/dp/B00011KLH0/ref=sr_1_8?ie=UTF8&qid=1317614137&sr=8-8
that is the right stuff as stated a couple of pages back and 9 foot is plenty enough to do the front bar
looks good but i can tell you it wont last long..
It has no problem lasting if applied right and if you don't scrape it, but then if you scrape a fibreglass one, it can smash aswell.
Anyway, due to interests, I'll put up another group buy soon :)
After having mine on for about 3 months now, I'm now trying to think of a longer term solution. This stuff looks good when it's first applied, but mine is looking in pretty perilous condition now. Cracks everywhere, shows up dirt very easily, and just doesn't want to stay stuck on (though that's an issue with my front bar not having enough surface area).
But having had the lip now and seeing how much better it makes my car look, I don't want to take it off :( Need to think of a way to attach it better I think...
  • 3 weeks later...
I honestly think this lip can be a long term solution if applied right.
I mean, to get it ripped off, you'd have to badly scrape a driveway, and even if you have a fibreglass lip, that thing would shatter anyway.
$25 lip vs $200-300 fibreglass lip...
  • 2 months later...
  • 10 months later...
I've looked at this thread a few times and am considering doing it to my 33 instead of a Nismo style lip which is more expensive and I'm not really sold on.
Has anyone been running one long term? Or did everyone give up on these??
I've had my rear ones on my car since i started this thread, don't have a problem at all. But the front, it got ripped off when i drove down a deep drive way lol (but i guess it woulda been worse if it was a fibreglass lip).
