110 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
So the question is, what is the best handling nissan out of the above and why? Note I am talking about the RWD GT-T versions of the skyline.
At a complete guess I would have thought the S15 would have been the best due to being the newest and lighter than the R34 but I have nothing to back this up with apart from weight, what do you guys think? If you can back it up with some reasoning that would be tops. I'm ignoring power as a metric as they can all be easily modded to 500hp if needed.
  • Replies 54
I have driven them all other than the S14.
Assuming we are talking about handling on a basic street setup not a full blown track car.
From them I think the best overall handling from a street perspective is the S15 aswell. While possibly the S13 might actually handle better on a track from being a bit lighter, I find that the S15 feels more solid/less clunky/smoother and gives a better overall feal which is important on a stret driven car. The steering also seems to feel a bit quicker than in the Skylines (not sure, might not be but feels like it).
However the best handling overall Nissan I have driven is a 370Z. Now just gotta get some one to give me the keys to a R35 :P
EDIT: Also since it is kind of part of the family and should be mentioned. The 300ZX was the worst handling Nissan import I have driven. The steering is horrible in it and requires huge amounts of lock to turn.
the S series cars should be the better handling cars due to them being the more sports car oriented range. the skylines are basically a sporty family car. i owned a 180sx and a r33 and i'd have to say that the s13 had a sharper feel to it. the r33 had a better ride thanks to plusher suspension. for an everyday comparison though, there isn't too much between them, and if built into a track car i think there would be even less.
Ive only driven an R32 R33 S13 and S14
The R33 was the worst out of them
And I think the S14 is the best the S15 should be pretty much the same maybe a little better as they are very similar chassis
Everything I've been told is that the skyline can carve the twisties, albeit not as well as some, but definitely capably.
I drive a stock standard AU falcon (read; cumbersome boat), and my next car will be a lowered 34, how much better can I expect the handling to be?
If you had stock suspension in the AU it will be amazing difference.
If both were set up with appropriate aussie road springs (4-5kg max), sway bars, appropriate shocks then the R34 will be better, but not amazingly so.
the difference will be noticable...... whether it is in a good or bad way will depend on what suspension it has been lowered with. it will handle better in most cases, but if you put in too stiff suspension then the first time you try to corner hard on a rough rough then you will find that you end up bouncing onto the wrong side of the road. i had this happen in my 180sx when i got new front suspension put in, and i was driving normally. that suspension only stayed in there for 2 days.
You're kidding me? A set of whitelines and some springs can have an AU handle ALMOST as well as a 34 set up for the street?
he is right. the stock suspension is designed for the generally shit aussie roads, so they are pretty soft. make a few changes and it will be a drastically different beast. there will still be a bit of a difference in feel through the steering wheel though because of the different steering wheel size as well as different steering ratio.
Excessive lowering will be detrimental to the handling of your 34 as they are double wishbone.
S series chassis are McPherson strut and I would not call them good handling cars by any stretch of the imagination.
Why not? They both are double wishbone front and fully independent rear ends and weigh similar amounts (1400 vs 1437kg). If you are setting the springs, shocks, sway bars, caster etc all up correctly, they would have the capability to be very fast on the track (provided they have the power).
What else does the R34 have that magically makes it a better platform?
Edited by Rolls
Yeah I'm thinking of just king springs in the line, as long as the shocks are in good condition. I don't want something too stiff (I want it to be my daily and have the falcon for emergencies).
Are there plenty of swaybar options out there for 34's?
Nothing really, I was labouring under the illusion the skyline was just "better".
Dont go kingsprings, get whiteline and bilstein shocks or something else decent like that. Or tein super streets are about the only coilovers that have reasonable spring rates for our roads.
Yeah it is funny how people just assume because it is a skyline it will be better, and say because it is a commodore or falcon it is a boat, there isn't that much difference once you start modding things.
Edited by Rolls
Thanks for the info mate, I'll definitely look into coil overs. I always wanted to, but was told that they'd probably be too stiff for regular street driving. I wasn't aware there was a coil over that was designed for the road.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
