I have just started research for a new engine build for me torana, this is the only forum I am a member of and most of you guys know a lot about forced induction so why I'm asking here. The plan so far is stroked 186 < 234, efi and supercharging it.
How I want to do it:
Pod>throttlebody>supercharger>2.5 inch pipe>400x200x50 intercooler>2.5 pipe>manifold/injectors>engine>3 inch exhaust
Now I read its not worth running a intercooler with this kind of set up, anyone confirm? I'm hoping to run between 10-15psi
Ecu is another thing I need advice on? And what other sensors should I add in?
Is there some formula to work out injectors and throttle body sizes?
I'm hoping for around 350hp does this seem achievable? I know its going to cost a lot, and the actual build is probably 6 months away, I just want to be prepared.
https://www.sau.com.au/forums/topic/367527-new-engine-build-idea/
attempting to get that sort of power out of a stroked 186 is going to take a reasonable amount of work. personally i'd just put in a modern engine with a turbo already bolted to it and then work from there.
as for running an intercooler, as long as it is a supercharger that doesn't just sit on top of the manifold then you will definately gain power from putting one on there.
So 234 is about 4lt..?
Could you get the injection manifold off a vk modified to suit.?
Have a look here.
http://forum.ejehclubqld.com/ehclub/forum/topic.asp?TOPIC_ID=8246
Look at the pics at the bottom of the page
Maybe add in a water/meth injection kit as they are cheap from the states at the moment
Edited by WHITER33GTS-T
you running a centrifigal supercharger I imagine cause I have no idea how you would intercool a roots type blower.
Centrifigal chargers are rubbish and you would be better off running a turbo than one of these..fitting a roots type blower will yield better results and is much easier to setup. Just get a 4 barrel holley manifold stick a blower on top with an injector plate on top or below that.The most I have seen is about 350hp from one of these and its a lot of work to get there when you could throw an RB engine in there and easily have a more reliable and user friendly 400 plus hp for the same outlay and if the engine goes bang simply buy another. Add to this the epa and engineering will be much more friendly with a new tech engine than an old one.. You can just get a conversion kit from CRS to bolt it all in could cost less than 5k if your smart and can make 500hp before you even need to open the engine.. Not doing it is crazy..
But yeah if you insist on a centrifigal then yeah use a VK injection inlet manifold, for 350hp just go 500cc plus injectors should cover it, maybe bigger to be safe, probably something like an old wolf 3d or similar should work for an ecu and shouldnt the TB go after the charger, just leave it in its original spot on the manifold
I thought about the rb option but doesn't apeal to me as much. I guess I want to keep the nostalgia feel to the car. The blower I am thinking of using is a harrop htv 1320. I planned to run it on the opposite side to the intake and run a pipe from under the charger around the front to the intercooler then to a custom plenum? I'm a fitter/machinist and have access to a miller and lathe so I planned on doing the custom stuff myself.
meh dont waste your time with an intercooler ,as I said get an old redline torker manifold or similar then maybe stick either stick 4 big injectors in a base plate made to mount the supercharger on the manifold or fab some injector holes into each individual intake runner. just use a water/meth setup if it gets too hot. Will be much neater setup this way :thumbsup:
Yeh alright this sounds the best way, cheers mate.
Nothing wrong with centrifugal blowers.
Friend i have has one in a Camaro that drives to the track, runs 9s, drives home on the same tyres.
1000rwhp of no problem!
look on a v8 anything will work because the v8 is doing half the work already..A well built camaro big block can do 9s without a charger
put twin turbos on the v8 it will go harder.. ;)
yes i thought you were running a different style of SC .i reckon a late falcon TB would do the job. Its 80mm I think....
here..about halfway down the page is a good manifold..
http://www.aussiespeed.com/index.php?option=com_content&view=article&id=9&Itemid=40
it is designed for carb but you could easily replace that with some form of injection, a top of the the line yella terra head and your stroker block. should go hard..
Yeah ill be adding one of them to the list, thanks for your help Arthur.
I joined the turbo202 forums and asked a couple questions, but they are a bit slow to respond so ill ask here to. Any benefits of running twin 38mm throttle bodys over a single 80mm?
And benefits of running say a 3-4inch spacer between the charger and intake manifold, like a tunnel ram sort of system?
I'd say no and no...
when you go about seeting up something custom like this your best bet I think is to keep things as simple as possible. it makes faults easier to find come tuning time. I would even consider using a carby it will be a zillion times easier.. though an injection systaem should yeild better results. i will look into some injection setups when i get home..
this sort of setup is what I was thinking.
its neat and reasonably simple but has no IC and the hardest bit would be setting up injection..
Alternatively i guess you could run a centrifugal charger look at these Raptor kits, then you can just use Vk injection setup and IC cool it..
http://www.raptorsc.com.au/kits.php?id=55
Im starting to think this may be an easier way and probably just as powerful but I like the first way better..
but shit man, 3200$ is more than I would want to spend on a red 6 you could buy a used rb25t for that and still have change..
stick with the rb ive done the red motor bit and the rb is leap yrs ahead . i used to race a turbo 186 with falcon 221 crank and a phill irvin alloy head using mechanical methanol injection and with all of that it just made 350 hp and only got a dozen or so meetings out of it without a freshen up .
it used to pop the welsh plugs out of the block till we made screw in ones . the block was o ringed it run carrillo alloy rods and aries forged pistons and cost a shitload to develop and maintain.
the rb is a proven product will make more power for half the head aches .
cheers dean
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
