I have just started research for a new engine build for me torana, this is the only forum I am a member of and most of you guys know a lot about forced induction so why I'm asking here. The plan so far is stroked 186 < 234, efi and supercharging it.
How I want to do it:
Pod>throttlebody>supercharger>2.5 inch pipe>400x200x50 intercooler>2.5 pipe>manifold/injectors>engine>3 inch exhaust
Now I read its not worth running a intercooler with this kind of set up, anyone confirm? I'm hoping to run between 10-15psi
Ecu is another thing I need advice on? And what other sensors should I add in?
Is there some formula to work out injectors and throttle body sizes?
I'm hoping for around 350hp does this seem achievable? I know its going to cost a lot, and the actual build is probably 6 months away, I just want to be prepared.
https://www.sau.com.au/forums/topic/367527-new-engine-build-idea/
attempting to get that sort of power out of a stroked 186 is going to take a reasonable amount of work. personally i'd just put in a modern engine with a turbo already bolted to it and then work from there.
as for running an intercooler, as long as it is a supercharger that doesn't just sit on top of the manifold then you will definately gain power from putting one on there.
So 234 is about 4lt..?
Could you get the injection manifold off a vk modified to suit.?
Have a look here.
http://forum.ejehclubqld.com/ehclub/forum/topic.asp?TOPIC_ID=8246
Look at the pics at the bottom of the page
Maybe add in a water/meth injection kit as they are cheap from the states at the moment
Edited by WHITER33GTS-T
you running a centrifigal supercharger I imagine cause I have no idea how you would intercool a roots type blower.
Centrifigal chargers are rubbish and you would be better off running a turbo than one of these..fitting a roots type blower will yield better results and is much easier to setup. Just get a 4 barrel holley manifold stick a blower on top with an injector plate on top or below that.The most I have seen is about 350hp from one of these and its a lot of work to get there when you could throw an RB engine in there and easily have a more reliable and user friendly 400 plus hp for the same outlay and if the engine goes bang simply buy another. Add to this the epa and engineering will be much more friendly with a new tech engine than an old one.. You can just get a conversion kit from CRS to bolt it all in could cost less than 5k if your smart and can make 500hp before you even need to open the engine.. Not doing it is crazy..
But yeah if you insist on a centrifigal then yeah use a VK injection inlet manifold, for 350hp just go 500cc plus injectors should cover it, maybe bigger to be safe, probably something like an old wolf 3d or similar should work for an ecu and shouldnt the TB go after the charger, just leave it in its original spot on the manifold
I thought about the rb option but doesn't apeal to me as much. I guess I want to keep the nostalgia feel to the car. The blower I am thinking of using is a harrop htv 1320. I planned to run it on the opposite side to the intake and run a pipe from under the charger around the front to the intercooler then to a custom plenum? I'm a fitter/machinist and have access to a miller and lathe so I planned on doing the custom stuff myself.
meh dont waste your time with an intercooler ,as I said get an old redline torker manifold or similar then maybe stick either stick 4 big injectors in a base plate made to mount the supercharger on the manifold or fab some injector holes into each individual intake runner. just use a water/meth setup if it gets too hot. Will be much neater setup this way :thumbsup:
Yeh alright this sounds the best way, cheers mate.
Nothing wrong with centrifugal blowers.
Friend i have has one in a Camaro that drives to the track, runs 9s, drives home on the same tyres.
1000rwhp of no problem!
look on a v8 anything will work because the v8 is doing half the work already..A well built camaro big block can do 9s without a charger
put twin turbos on the v8 it will go harder.. ;)
yes i thought you were running a different style of SC .i reckon a late falcon TB would do the job. Its 80mm I think....
here..about halfway down the page is a good manifold..
http://www.aussiespeed.com/index.php?option=com_content&view=article&id=9&Itemid=40
it is designed for carb but you could easily replace that with some form of injection, a top of the the line yella terra head and your stroker block. should go hard..
Yeah ill be adding one of them to the list, thanks for your help Arthur.
I joined the turbo202 forums and asked a couple questions, but they are a bit slow to respond so ill ask here to. Any benefits of running twin 38mm throttle bodys over a single 80mm?
And benefits of running say a 3-4inch spacer between the charger and intake manifold, like a tunnel ram sort of system?
I'd say no and no...
when you go about seeting up something custom like this your best bet I think is to keep things as simple as possible. it makes faults easier to find come tuning time. I would even consider using a carby it will be a zillion times easier.. though an injection systaem should yeild better results. i will look into some injection setups when i get home..
this sort of setup is what I was thinking.
its neat and reasonably simple but has no IC and the hardest bit would be setting up injection..
Alternatively i guess you could run a centrifugal charger look at these Raptor kits, then you can just use Vk injection setup and IC cool it..
http://www.raptorsc.com.au/kits.php?id=55
Im starting to think this may be an easier way and probably just as powerful but I like the first way better..
but shit man, 3200$ is more than I would want to spend on a red 6 you could buy a used rb25t for that and still have change..
stick with the rb ive done the red motor bit and the rb is leap yrs ahead . i used to race a turbo 186 with falcon 221 crank and a phill irvin alloy head using mechanical methanol injection and with all of that it just made 350 hp and only got a dozen or so meetings out of it without a freshen up .
it used to pop the welsh plugs out of the block till we made screw in ones . the block was o ringed it run carrillo alloy rods and aries forged pistons and cost a shitload to develop and maintain.
the rb is a proven product will make more power for half the head aches .
cheers dean
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
