Found this info with a quick goggle search
Revlimit Motorsport (RMS)
Unit 3/ 38 Cohn St Carlisle 6101 (08) 9470 2444
- Link
- Autronic
- UTEC
- Motec
Maximum Motorsports (MMS)
66 Westchester Rd Malaga 6090 (08) 9249 7444
- Link
- Autronic
- Motec
- Unichip
- ECUTEK
Speedworks
4 Carbon Ct Osborne Park , WA 6017 (08) 9242-8888
(own 4WD hub dyno)
- Link
- Autronic
- Motec
- Power FC
- UTEC
- emanage
Race Torque
16 Action Pl Wangara 6065 (08) 9302 6388
- Link
- Autronic
- Motec
- ECUTEK
XSPEED
18 Zeta Crescent, O'Connor 6154
Parts : 08 9331 8088
Garage & Dyno : 08 9337 3288
- Link
- Autronic
- Motec
- Power FC
- emanage
Hyperdrive Motorsport
Unit 1/ 28 Vale St Malaga 6090 (08) 9209 3100
- Autronic
- Power FC
West Racing
Unit 5/ 6 O'Malley St Osborne Park 6017 (08) 9446 1913
- Motec
- Unichip
- Autronic
Tony Flood
9/ 91 -93 Kew St Welshpool 6106 (08) 9472 1800
- Motec
- Link
Intune Performance
1/15 Murphy st O Connor 6163 WA
0414 874 824
- Motec
- Xcede
- Autronic
- Link
- Haltech
- Motec
- Power FC
All Star Garage
Unit 3, 21 Vale Rd Malaga (08) 9248 7433
- Link
- Autronic
- Motec
- Power FC
- Verso
https://www.sau.com.au/forums/topic/367537-r32-gts4-tune/#findComment-5862462
thanks everyone. sorry about posting in the wrong thread
i have a stock auto ecu running atm and a stock manual ecu spare. i was gonna swap them over but was told there will be no difference..
i will be installing a new clutch and light weight flywheel then a fmic then i will be looking at getting it tuned and the boost jacked up to 12psi.then shim the rear diff and some 75w-140
to get the box out will i have to drop both tailshafts?
what style clutch do you reccomend? cusion button or pucked
thanks for all the feedback
https://www.sau.com.au/forums/topic/367537-r32-gts4-tune/#findComment-5864100
yeah i know all too well about marking tailshafts. my marks rubbed off at work one day and after looking at it for a while igot it back to where i thort it was originally, road tested and no vibrations , lucky.. now ive got a nice white pait marker.
how much for a chipt ecu, or aftermaket ecus?
car seems to hunt at idle sometimes, im thinking lazy o2 or vacuum leak
gonna go with the cusion button cos peak hour traffic is a bitch and planning on doing trak days but not to often.
what would happen if i ran those mods on the stock ecu with no tune?
https://www.sau.com.au/forums/topic/367537-r32-gts4-tune/#findComment-5865746
RRP for a Type 2 NIStune board is about $260 delivered.
Hunting is probably a dirty airflow meter.
RB20 ECU's are pretty tolerant, with stock turbo mine handled 14psi without throwing a fit. It will just run rich and not make as much power as it could be making.
https://www.sau.com.au/forums/topic/367537-r32-gts4-tune/#findComment-5865815
Anything that doesn't leave a residue behind will work on the afm.
The Type-2 NIStune board suits R32GTSt/GTR (among others) and is a daughterboard that is plugged into the stock board (that is putting it simply). It gives you full tunability in realtime over the consult port :thumbsup:
https://www.sau.com.au/forums/topic/367537-r32-gts4-tune/#findComment-5866290
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
