http://www.facebook....178348732217498
Time:Sunday, July 3 · 10:30am - 4:00pmLocationMeeting at 10:30am at the National Automobile Museum of Tasmania, then at 11:30am cruising via Henry Street to Myrtle Park!
Created ByHeartKids Car Bike Show, Jonathan Chandler, Kylie Smith, Tassie MuscleCarsMore InfoTassie Muscle & Classic Car Cruise.
- TO MYRTLE PARK!
Sunday the 3rd of July 2011! Details and sponsors to be announced soon!Plan is to leave the Museum Car Park onto the Esplinade, then past KMART and up Henry Street to Ravo, right into Faraday Street to Waverly and out to Myrtle Park... No traffic lights and we can stay as a group!
Supporting children Battling with Heart Disease
Edited by Addicted2BoostR34
Yea I mentioned this somewhere. To guys who were interested, a continue on to Scottsdale and back for a run through the sideling.
yer i seen it in like makeing tas a sua club thought id make a page to see if some other skylines will come with me!
ECus should be right up there on everyones shopping list, you get so much more out of all your other mods when you tune your car. Plus you'll get more fuel economy too
Yea ecu's are my latest 'hear all these names but have no farking idea' lol. Need to research into them a little.
talk to the guys on here and think about what you need in the long run i went from a vipic street tuned to a haltec dyno now im getting a nistune dyno tuned for wat i need and keep working on it from there :D
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
