post-3332-0-69250600-1308368684_thumb.jpgpost-3332-0-69250600-1308368684_thumb.jpgFor sale is a brand new set of Porsche 996 Cup Car Brembo 6 spot calipers and Brembo 355mm x 35mm rotors.
I will also throw in new pads.
The calipers are brand new and have ceramic pistons, these are massive calipers and will need a minimum 18" wheel
Brembo rotors are about 25-30% worn.
All you need to do is get custom hats and brackets made up.
Price $2,600 ono
Would prefer a Melb buyer
Thanks
Darren
https://www.sau.com.au/forums/topic/368151-996-porsche-cup-car-brembos/
Are these the ones that are backwards or something?
by the look of it, they are set up to run towards the rear of the wheel, rather than in front as per the standard skyline caliper.
the larger piston should be in the dirrection the rotor rotates(rotor going clockwise, should be last piston past by the rotor).
so if mounted as currently set up, the piston will be on the wrong end.
you should be able to swap the bleed nipples, and transfer pipe(possibly have to get one made up), and youll be fine. :thumbsup:
personally, if i had the cash, id snap these up, hot looking calipers, with pads and rotors...
just saving the dollars as we type.
good luck with sale, will be an awesome addition to someones car.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
