honestly do a search....this has come up several times.
brent is online here as nengun anyways. i have only heard good things about nengun...and the last time i bought a ttimer+harness...when the harness was sourced it arived roughly 2-3 days later via ems or something like that. i find his service to be professional and from that i wouldnt have second thoughts buyin from them again. well thats my review anyways.
i did a searchand found at least a lot of people have orderd but couldn't find any info on larger orders, or problems which i suppose is a good thing,
so ordering turbos for 3500 shouldn't be risky then?
cheers feelas
Hi tribex, I have bought a few things from Nengun, never had a problem. Small items come in no Import Duty or GST but larger items sometimes get caught. So budget for 10% Duty and then 10% GST on top of that. If you don't have to pay it, you're lucky.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
