My car is down at the tuners(yay) and got a call at 8:47am today. I asked them to fit my injectors on and change my fuel filter. I was then asked what fuel did I use. I said 98 Vortex. He said are you sure its not E10? I'm like dead set 100%, Ive got the receipt. Then he said the fuel is clear and not the usual colour of 98. This scared me and also made me angry as I have been filling up at the station down the road for ages. He said don't worry we will test the fuel to make sure it is what it is and if there are any issues we will call you back. I still haven't(and hope not to) got a call back.
Would it be fair to say that with the small amount of fuel trickling from the fuel line is not enough to see its colour? Ive had fuel squirt here and there before(when changing the pump) and it has always looked clear. Only when taking a large amount did it get that yellowish tinge to it. If it does turn out to be E10 fuel, I am really going to lose my temper at this petrol station and demand compensation. Ive got receipts and when you test fuel I am sure it can be traced to the supplier of the fuel.
Will this petrol station be held responsible if it is in actual fact E10 fuel coming out of the Vortex 98 tank?
Is my theory likely? That in small amounts its not enough to show colour? I also never thought E10 was clear, fuel has always been coloured(Its dyed apparently). Any input or comments are welcome.
Yeah, I am pretty sure you can sue the station and its name with the consumers rights. They advertised it as 98, so there's no reason for E10 fuel to be there, unless you used some other service station.
Good luck.
I thought Advan sold wheels and tyres? xD
Probably he meant his tuner shop name.
Advan Performance not Advan wheels lol.
Well I haven't got a call back and I was just looking at the fuel in our can down stairs(98 and 91). In small amounts they look identical. Hopefully all is fine because I really don't want to have to do anything more.
My brother changed his fuel filter in his EVO a few weeks ago, the Caltex 98 that leaked out was a clear/yellowish colour.
I don't know how one can tell the octane of a fuel by the colour... I had the understanding that petrol was colourless until additives were added to it.
Sure did....
They really need to run it up on a dyno, the timing that 98 can take vs 91 will make it immediately obvious.
I got a bad batch of fuel that almost destroyed a brand new motor...and Shell stonewalled me. Their "investigation" found no issue. And as I didn't suffer financial loss, Fair Trading had no interest
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
