Don't thnk the traction control would help if anything it would make it worse.
In my R34 when the TCS kicks in it cuts power for a good second or so. So if it happened whilst he was on a steep driveay he wild just be sliding down slowly down the driveway :)
I only gave it some AFTER goin up a car length from flat area, then it started wheelspinning and not goin up, so i freak out n apply more gas hehe- and effectively doin a burnout!
Driving style in my opinion.
You didn't think to try get a slow roll happening before you hit the driveway?
& also did you try letting the clutch out with no throttle, getting a tiny little roll-on, or at least loading the driveline, then gently accelerating?
545nm, a wet 30 degree slope and no traction control. Yep, that'd do it.
+1
Did you try getting a little headstart? Reversing back then going at it hard?
"Get a bigger hammer" comes to mind..
Maybe you got a point, WLSPN, you could be right, I didn,t do those things, to the guy below you, VONCINA, ha ha yeah I tried that of course, all I got was massive wheelspin and burning rubber lol...
sounds like driving style is playing a bit of a part in it, and the stiff suspension may be playing a part if it isn't a smooth transition from flat to steep, mainly if you have to take it at an angle as the inside wheel probably has bugger all weight on it. a mate of mine had a ceffy where if you jacked up a front wheel the rear wheel on the same side would come off the ground it was so stiff.
was it spinning both wheels, or just one? if both then it is a diff issue as it isn't engaging the LSD. not saying that the diff is shagged, but it is worn.
to be honest, the tida should've had the most problems going up being fwd. all the weight would be over the rear wheels and the front wheels would be light. there is one intersection in town on a steep hill and if you try to take of with any sort of haste in a fwd it will spin the wheels. in a rwd car you can take off fast easily.
my advice would be to simply idle up it with bugger all throttle. keeping it off boost will drastically reduce the chance of wheelspin and it will be putting out much less torque than the lexus would be. if it still whelspins then it is your suspension and your diff.
If you were trying to go up slowly, then its not rpm or torque, because you regulate that with the clutch. Still suspension will definitely be a problem, as it will significantly un-weight one wheel, in which case you really need a working LSD to get any forward movement.
Any idea if both wheels were spinning or just one?
Don't know about that, my mate who was outside watching pointed out that the left rear wheel (outside of the curved driveway) was spinning but that was because he couldnt see the right inner wheel from his standpoint. I dont think its the diff/LSD because my car had straightened itself up on the straight part of the terrible slope and then wheelspinning like crazy. Which means both rear wheels getting equal grip at that time..
By the way my turbo kicks in around 2500rpm when it sees positive boost psi, by 2800-3000rpms it is at 12psi. Around 2500-3000rpms is what I would have been doing going up the slope after it started losing traction completely.... I would have driven in at 2-2500, it slipped, and then gone to 3000rpms and up to keep it from rolling back - but it never rolled back,. With the handbrake on and the car angled up the slope, I let the clutch out normally and throttle would have been 2500 and up - and massive wheelspin without movement.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
