Hi,
I have no idea where to go in Perth to get my turbo timer put back in.
i had an immobilizer installed for licencing reasons and the gentlemen who put in the immobilizer disconnected my turbo timer without telling me.
i need it back in asap as its my first turbo car i have no idea where to take it.
Can anyone suggest somewhere that will do a good job and not cost me my whole paycheck?
https://www.sau.com.au/forums/topic/368597-turbo-install-in-perth/
any of the major shops
Xspeed, hyperdrive, allstar garage etc.
not sure what they would charge but it cant be too hard.
Why dont you get onto the immobiliser install guy and take it up with him? usually u shouldnt f*k with any other of a cars systems if you are doig a job right so get him to hook it back up again...
Hi Chloe,
Do you know what the turbo timer is? (greddy, apexi etc)
I'd recommend posting those details up here first, depending on how bad it's been disconnected one of the dudes on here may even be able to do it for you. (ie: might just be one wire)
Alternatively call up a few of the workshops and explain you have a '_____ turbo timer that has been disconnected on an R34, how much to install it/fix it then work out based on price and reputation of the workshop where to go.
In the meantime don't worry too much. The manufacturers don't make the cars with turbo timers so it's not necessarily vital, just drive your car easy for the last leg before your destination (ie; dont thrash it to your driveway then switch it straight off) or alternatively just sit with the car on for a minute before switching off =)
-Steve
Yeah, my first turbo car (180) had one when I got it, but haven't bothered with one in any other cars since. Just drive nicely and off boost for the last couple of minutes before you stop, and then you should be safe. I got into the habit of doing that when I was living at home with the olds, had a really loud exhaust on my 33 and went out cruising late-night, didn't want to annoy the neighbourhood by leaving it idling away in the middle of the night.
If you really want it though, any decent auto electrician shouldn't have any problems doing it.
Edited by Dingus
Hi Chloe,
-Steve
Hi Steve,
I will have to look when i get into my car after work, its still in the back of my car.
it was completely cut out, all the wires were cut and they didnt tell me, i notcied it on my back seat when i was half way home so went back and they said they wouldnt be able to install it because 'its legal to have turbo timers' i thought that was bs i have seen a lot of my friends with turbo timers
Thanks for the advice tho
Chloe
you can have one legally if it is part of the alarm/emobiliser.... so that if someone tries to get in then the engine will shut off...
i have passed the pits with mine on and he simply asked me to shut the engine down.... same as the police whenever i get pulled over...
dont waste your $$$ going to a workshop.any good auto electrician can fit/refit a turbo timer
Hi StevenCJR31
I dont know any auto electricians, hence why i asked on here about it. If you can suggest any that may be interested in helping me out, would be much appreciated. : )
Chloe
They are not legal if they are built in to the alarm or immobilizer , they are tolerated though and generally the pits and police are OK with them.
ADR 25-Turbo timers are not to be fitted to vehicles manufactured on or after 1 January 1972 (ADR 25 Anti-
Theft Locks). ADR 25 requires that the normal function of the engine only occurs when the ignition
lock is in the engine on position.
You may find it difficult to find a reputable person to fit the turbo timer with the immobiliser , not because of the ADR issues but because a relay bypass must be wired into the alarm to disable it while the turbo timer is operational , leaving the car unsecured and the installer liable.
here is a nice thread , read the comments by the alarm installers in it and the stuff on bypassing security
http://www.skylinesaustralia.com/forums/topic/356357-turbo-timer-vs-alarm/
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
