mine stalls if i pull the plug??? is that normal.. i put the idle down to 1000rpm today and it stalls like a bitch at every traffic light.. but is alright after a while of sitting there.. i also listened VERY closley and could hear a air leak some where. im pretty sure now that this is my problem just gotta find the air leak..
  • Replies 41
Just to throw more fuel on the fire....
My car does this (did this). I changed the fuel pump on the weekend and found the severity of the surging (if you can call it that) was reduced significantly, most mornings i can't even feel it anymore.
Which leads me to think it may have something to do with the fuel pump voltage controller, which drops the voltage to the pump at idle and cruise to quiet it down and improve it's life span. You may find it's switching between high and low pressure or something when the car is cold and trying to pump more fuel in?
I don't really know it's this, just theorising based on my experience.
I know this is for an RB20, but I had some very weird behaviour in my 33... hunting, lack of power, etc... then stopped the hunting, just ran shite... turned out to be the coolant temp sensor. I mention this because we (the mechanics and I) thought it was the o2 sensor at first... then the AFM.
To test this, go for a drive, get everything nice and warm, then yank the cable off the temp sensor. If the engine doesn't go nuts and rev and carry on, then it's that. And if it does, just pop it back on, all good.
Free engine self-diagnosis, gotta love it. :)
Okay... erm... hard to explain without a picture, but standing in front of the engine bay, look down towards the oil filter... in your way will be a 2" sized pipe, with a sensor situated about 4 inches out from the side of the block, on top of the pipe.
Hope this helps. If it doesn't, I'll find a photo.
edit: Oh, and the pipe will be leading into/away from the radiator.
OK... I found one of the problems.... The serging of idle is being caused by the ACC Valve. Located at the rear of the plenium chamber. However all said and done... try and find one... I have disconnected it completelly and the car is not serging...
However the stalling is still happening. I thought it may be the fuel pump so i have re-wired the fuel pump to be on high presure all the time. I alos have a fuel pressure reg with a gauge so i can see the preasure is not dropping when this happens. As mentioned earlier in the piece i replace the 02 sensor. Today i did some spark plugs.
Now the Acc valve seems to be a solinoid... It is a closed circuit and when voltage is applied there is not movement in the valve... My question is how does it work and whats its purpose exactlly??? The operation of the valve is funny, you can push the tip in about 10mm and it will spring back, this corosponds with another tip on the plenium... It does not send signal as i said before its closed circuit... So im assuming its a soliniod... but it does not puch out so im beet... Any ideas...
Also im pretty sure the stalling and carrying on is cause by a faulty sensor of some sort.
Also about the colant temp sensor, if you disconnect this sensor the car should return to a high idle, this is caused by the computer going into limp mode. Has nothing to do with wether its faulty or not....
I have replaced 2 before with no changes (this info is from the guys who replaced it)... On the bright side the colent temp sensor on the rb20 is the same as a nissan Maxima so the cost of getting one new is only $50 from Nissan...
Anyway guys, i think its time to through the whole thing....
I have spend over 15g's on this car and still its one prob after another...
thats what i did.. but i screwed mine to 1500.. wow.. sitting in traffic and couldnt hear much (3.5in exhaust and 1 muffler) got too annoying.. col-gtsx - when i replace my motor ill lend you my spare idle control valve and you can try it. not sure when it will be but ill let you know and if you still got problems well give it a go. another thing to try is look at EVERY VACCUME line in your engine bay!!! try fuel filter if it hasnt been replaced for a while.. your fuel reg could be stuffed (you said you have an adj one.. have you taken the vac line off the std one and just let the fuel run through it? could have a leak some where) hate to say it but my head gasket is causing my idle to screw up.. mite be worth a check. the other nite i got the contact cleaner out and cleaned some of my coil packs also noticed on the wires going to the coil packs (the loom thing) that a lot of the wires didnt look the best.. looks as if they were burnt etc.. it would be a nitemare but mite fix it if you replace the wires (:D) haev a look at the back of the plenum but under it and you will see another regulator type device on the fuel rail whats this for??? have a look at the vac line going to that is it cracked i changed mine and tried taking the one that was on there off.. took a while cause it was the original one.. there are just some things i was thinking about tonight. hope it helps.. if anything can/does at all..
Yes.... the cold start item will play up when the engine has passed about 150k's but has no real direct affect with the operation.... cant stall the car just makes it a bit jerky on the pedal when cold... but this cant be helped anyway...
The AAC valve is certainlly the cause.... I am replacing it next week with a gen part.... but ill do the collant temp sensor as well as this after noon i droped the endless chain on it and broke the %$#ing thing....
My issue sound very similar to this one
http://www.skylinesaustralia.com/forums/sh...4564#post814564
abve i talked about the timing changing all of the place and this can cause it.... Well in the post above another guy has measured the timing when the fault occurs with his motor and its all over the place....
Only 3 things control the timing...
1> CAS
2> ECU
3> AAC (in directlly thro ECU)
Ummmmmm ideas.... Anyone got a spare CAS for a silver top i can borrow for a week????
OK... problem gone for like over a week now...
Then as im starting to be a little happy about it... this arvo it did it again.
Revs up and down... get out of the car, unpluged the AAC valve and the car returns to normal... However with this unplugged it has a tendancey to stall un-expectlly... So i got to cross a major road in Brisbane to limp it home and what happens.... Yep you guessed it...
Then to make things even worse. The Police were sitting waiting for me to push it out of the way only to give me a hard time.... It took them 20 minutes of checking the car inside out to find that its perfectlly legal.... However they didnt look at the rego sticker which had expired over a month ago....
Because the car has been off the road for a while i forgot all about it...
Anyways they were pretty nice in the end... I guess they deal with some pretty nasty people everyday. But still thats 20 minutes of my life ill never get back.
Back to the story... Saving at the moment for a full and i mean 3 day type full service and tune... New AAC valve should be here in a few weeks from Japan ($300) then tune and all should be good.... In the mean time ill just drive it a little to keep the juices flowing
OK guys... the problem is solved.... Yes you heard me i fixed it...
Cost $40
Time taken 10 minutes
Faulty AAC Valve... Hardest part was trying to find the part.... Only taken 3 weeks, but anyways not the point... Im over the moon now... I can finally get the new FMIC done in the next couple of weeks... Then is the AVC-R... Then ill see you a jamboree... Wanta (im mean gonna) crack mid 12 second pass....
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
