I was changing the dump pipr on my 33 gtst( stock)
and forgot to strap in the o2 sensor plug and it melted through on the turbo
car now wont start, iv tried new plugs, no o2 sensor.
Any help would be good cheers
can the car start and idle with no o2 sensor?( no driving though dw)
https://www.sau.com.au/forums/topic/368945-02-sensor-plug-burnt-car-wont-start/
yes, yes it can. will just run a bit richer at light load (instead of the AFRs being around 15:1 it will be about 12:1). at heavier throttle % then it won't be any different as the ecu ignores it anyway
Just rewire it mate. Easy as. P.s I disconnected the O2 wire from my stock computer and my pfc and the car stalled both times. What does that tell you?
it tells me you disconnected something the ecu actually needs, like the cas. as nismoid said the o2 sensor is not needed for the car to run and drive. its a fuel saving device and it only used when cruising along at a constant throttle
Get the wiring diagram and start looking for where the common power feeds are to see what you've shorted out. It is pretty clear that when the wiring melted on the exhaust that a big bad electrical failure happened. It doesn't take a rocket surgeon to work that out.
Haha probably aye. Actually now that I think about it, it was the wrong wire. Dur... I remember that I unplugged the wrong wire and it didn't run and then realized and got the right wire (the clear one). My bad :whistling:
Hey guys in a bit of a pickle!
Was driving the other day and car just cut out on me and wouldnt start. I then looked under the hood and saw that i melted my o2 senssor wires onto the turbo manifold and that appeared to be the problem until i disconected it and tried starting with no o2 seonsor and got nothing. Next i took off the fuel lines into the engine and turned ignition on and found no petrol pumping or any sort of prime noise! So i took the fuel pump out and stuck it directly into the engine and ran it manually and the car started and reved up. So i assumed i had stuffed one of my relays to the fuel pump. To my understanding it is either both or one of the one behind the ecu in pass kick panel and in boot to the right of fuel pump fuse. They appeared to work fine after testing. Next i tried looking at the pump control unit and found no burns on the board but am not sure if there would be from 12 v? So not sure if thats working or not. Also i ear there is a ballist resistor connectin to the fuel pump in the boot which i have not yet looked at but am not sure what its duty is and if it can actually short circuit?
Need help!
Oh and also tried a mates ecu and nothing. So inconclusion there is no power on the wires on top of the fuel lid
had this exact same thing happen before... O2 sensor wirings have 12V power and signal wires/ground going to ecu... if you short them together it WILL fry the ecu.
lucky for me i fried an injector driver for cyln 5 on the circuit board so it still ran on 5 cylns... i was able to un solder the fried driver and replace it.
Sounds like it depends what sort of shorting happens as to whether it frys the whole board or just a certain thing. It could also be in safe mode. But i noticed power to the fuel pump after i put a direct negative to the relay in the boot at the pump started to prime.. I then took it off and it still primed for another second or so and since that direct negative its been working without my direct negative but using the ecu to turn it on again! No idea why?
The ECU has a -ve trigger for the fuel pump. On shorting the O2 you must have fried a common point somewhere.
Try using a multimeter and testing the fuel pump trigger on the ecu (-ve output), it will stay on for a few seconds if the motor doesn't kick over.
Work from there!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
