The deatschwerks 440cc are $430 plus postage so I think il go that way. I will never run any of that fake fuel in my cars, and I can accept that my stagea is a heavy lump so 250 4wkw is plenty. If I want something quicker il just get a new car. The stagea is just my daily/ tow car so as long as it can tow happily I'm happy to drive it. My biggest problem for now is my 4000rpm rev limit. I can't wait to use the other 3000rpm again.
I'm using the 342, no issues at all fitting it, electrical plug is even the same as the nissan one.
I believe the only difference between the 2 is the inlet and outlet are inline on the 342 where as the 341 thet are on opposite sides. Flow rates/performance is the same for both pumps though.
sorry to hijack thread, but I'm wondering if the z32 afms are supposed to have mesh on both sides? I saw one for sale on here, then looked at mine.. which only had mesh on 1 side.
is mine brokies?
/hijack
is mine brokies?
/hijack
@ hijack; people remove the screens for a slight airflow increase; not sure how much is in it.:sleep:
The 25 ones only have mesh on the inlet side - can't remember what my Z32 looked like but I would guess it would only have mesh on the inlet side as well.
is mine brokies?
/hijack
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
