What car was your first taste of boost in??
Mine was in an S13 CA18DET Silvia. At the time it felt bloody quick!!! Me and a mate were thinking that it wouldnt be much faster than our N/A r31's LOL.
I would love to experience how quick a GTR feels!!!!
So when and what was your first ride in a turbo car??? and what did you think of it???
Cheers
https://www.sau.com.au/forums/topic/36937-your-first-taste-of-boost/
  • Replies 58
1st taste of boost was in my mates 180SX totally stock then when i worked my ass off got myself a 32 OHHHHH BABY it was like heaven on earth..... but laster that week the devil (cops) rained on my parade.... it was worth it!
only ever being around N/A cars as i grew up i thought the vn ss was quick but when i had my first taste of a 11 sec vl turbo i think i had to be revived in the back seat, such a rush and ever since then, i personally, dont know how i wont want to own a car that isnt turbo!
my mates S14a 200sx put me in my seat. he's like "Still think only milk and juices comes in 2L?" my kingo at the time had a 4.2L V8, and it had nothing on the silvia. Thats what made me decide on a Skyline, because i just can't go to 4 cylinders...
