Is there much of a difference in Coil packs?
For a non turbo GTS 1996 skyline for daily driving?Done about 185,000km so far.
I have one starting to fail which will be replaced .
Although the others seem ok is it reasonable to replace them all.Do they wear out?
getting the mechanic to do this several times isn't cost effective but I don't know how long I can expect these to last under normal conditions.
If I could do this myself, rather than pay the mechanic, I would only replace the faulty one.
IMO you may as well replace them all. Then it is something that you don't have to worry about for a number of years....
EDIT: as the coil packs are all well aged it is now just a waiting game until the others go.
Edited by Shazza24
Like the others have said swap em out mate. Once one has gone, its probably only a matter of time (and short one at that)
I replaced one of mine and it ran well for around 2500km, then another failed. I immediately just wished i had forked out for the new ones.
You have to realize that all the coil-packs were manufactured the same, and now have done the same number of km's under the same conditions, and are all equally as worn out as each other, as one has failed, you can guarantee that the rest are on their way out. Replace the lot, and fit god plugs while you're there. Otherwise, it'll end up costing you more to have them replaced one by one, and fuel economy etc.
Mines run about 93,000 kms and one has now failed, on my car at least, the coilpacks are rather hard to access (thats what my mechanic told me) and if one fails, and you fix it, and another fails, then the labour costs will be alot just to replace one again so its a much safer idea just to replace em all :)
Thats gotta suck for plug changes etc too! Must be an r34 thing, the 33 (series 2) is a ridiculously easy job.
it's really not that hard to get to your coilpacks on an r34. just sounds like a good excuse for your mechanic to butter you up for an expensive bill
i just bought my r34 and have been pretty disappointed so far with things i've found so far on a car that was owned by a guy that had it straight to a mechanic for any little thing, not to mention basic oil and plug changes.
protip: learn how to do basic things yourself
i've heard that the sparkies and coilpacks are a bit difficult to get to on the 34s, the guy pointed it out to me and it appeared like it was under a fair bit of engine or something? Two different mechanics have both told me its a bit of a difficult job, thats why they
Im being charged about $130 bucks for the labour to get to the coilpacks ... might even just change the sparkies now cos its almost due for its 100k service so we dont have to pay for the labour to get there twice?
I really dont know much about mechanics - im trying to learn some stufff - thats why i got the sexcel :)
a few minor problems with the sexcel, gonna fix it up then move onto something else and hopefully should have a good idea and be a bit more confident to do stuff myself
hope to one day buy a blown engine and try and fix it up or something :)
get a service manual some reusable sandwitch bags an masking tape to label the bags of where to bolts belong and even go to take some photos during pulling everything of a reference. coil-packs arent too difficult, try replacing all the welsh plugs with the engine still in the car. if your after a temp fix wrap the coil-packs with good electrical tape.
its not hard doing it yourself. if you've got a bit of common sense then you'll be fine.
Re: coil packs. if you get lucky and have the coil packs with the copper inside then you can usually get away with cleaning up the surface LIGHTLY with a dremil. this worked really well for ages till i got a set of splitfires. they tend to accumulate a fair bit of crap over time.
Thanks for the replies.
I will now replace all the coil packs
for a ,R33 GTS non turbo 1996 skyline 4 door ( 180,000km )
I just drive this as the family car.
Now , which coil pack is the most reliable and what sort of cost am I looking at per coil?
If I don't go genuine replacement or should I
well for mine genuine is MUCH cheaper, 220 bucks for the parts, 120 bucks for installation.
for an aftermarket set you're looking around the 500 - 600 bucks for the coils ...
i dont see the point paying 400 bucks more for the aftermarkets especially since yours is a family car
coil packs WILL fail if you have an R34, R33 and R32 are a different story
it's actually quite easy to get to the coilpacks and change them yourself, just takes about 4 hours if it's your first time, you'll need a socket wrench, allen keys and pliers.
DON'T make the same mistake I did and change 1 coilpack and 1000kms later, another one failed costing me an unnecessay 350dollars extra! Replace the spark plugs while you're at it too and DON'T cheap out
When the mechanic did it he put in 6 copper spark plugs and a 2nd hand coilpack
When I did it, I put in 6 new iridium spark plugs and 6 new yellow jacket coil packs, not a problem ever since!
DON'T CHEAP OUT!
EDIT: yellow jacket coilpacks are 420 dollars inc delivery (they are almost identical in performance / durability compared to spitfires)
is it worth it to buy aftermarket ones vs the stockers?
ill definitely pick up some iridium or platinum sparkies and get them fitted at the same time as the coilpacks ... id feel bad canceling now since he's already ordered the coilpacks for me and stuff. the cars almost due for its 100k service anyway so i really may as well!
$590 for 6spitfire coilpacks and $1272 for originals from Nissan
Bought the spitfires and seem to have noticeably more acceleration now.
Can I expect my fuel economy to stay the same if I don't change my driving habits?
Edited by samuri
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
