  • Replies 161
Posted Images
Nice! About time I had a fellow Stagea driver in this section. Welcome to the forums, and welcome to Stagea ownership. :D
alan_key - Do you live on the beaches? And have you been looking at The-Lowdown lately ;) Turned out good! Maybe use another flash on camera right for some more fill and to kill the shadows?
Yeh i live on the beaches. and haven't heard of that site till now, seems like they've been using that spot too ha. Nice rig shots, wish i had a decent rig
Edited by alan_key
During my lunch break yesterday, I snuck down to the creek to find out what was making all the noise.
Oh yeah... found out that some of my V8 shots from clipsal will be used in the Bisley Workwear catalogue coming out soon too :)
I live on the Beaches too Alan. If you see a white evo 8 MR driving around give me a toot! :)
Will do!
MaTBoy nice shots, just wondering do you use a monopod or tripod when you're panning? last time I just did it handheld with IS and was getting pretty inconsistent results, either i just need practice or im doing it wrong ha
I never use a monopod unless i'm holding a 400 2.8 or 500.
Turn the IS off and practice your technique more. Panning is all about technique. Unless you were shooting stupid shutter speeds below 1/15th. I'd recommend starting at 1/100th, get consistent results, then drop down to 1/80th etc...
I usually pan at around 1/40th-1/60th depending on if i'm getting paid or not lol.
Hey Fellas, had a good play with the camera last night. Some serious effort and some just goofing around.
Hey Matt, Kory & Nick these are taken at the netball courts just behind my house. It backs onto the bush which makes it a great locale for the dark bush sihouettes. We should set up a meet there and see what you fellas think of the location.
(I call that second to last photo - "my rocket ship")
oh yeah, was going to add that I bought a ball cap from bunnings that has 3 l.e.d.'s in the brim. one directly straight ahead and two pointed down from the brim at about 30 degrees. It worked a treat for this kind of work. Was funny cause I kept feeling like the Blair Witch project with the light pointing any direction I looked.
Was well worth the $20. For you noctural photography buffs would highly recommend.
patience, my young padawan apprentice. In time the power of the dark side will reveal itself to you.
Location looks quite good. worth a future investigation. Good to see you're out there playing around :)
here's a couple from twilight on friday night.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
