  • Replies 164
Updated list
RB32(just under 3.2)$3500 Block with:
Custom ordered CP pistons(used, matched to bore)
Sonic tested and Cryo sleeved
Billet twin cam belt pulley adaptor
Stainless steel Welsh plugs
1.1mm head restrictor
Nisspeed 4WD sump Adaptor
Block milled for high HP Sump adaptor fittment
ARP head stud kit
Nisspeed oil pickup for extended Sump
RB26 Sump, extended with Baffles and Gates
Bore has been cross hatched for reinstall of pistons
Decked
6boost Twin turbo manifolds $1000
Heat wrapped and thermatec coated
come with Tomei metal shim gaskets and nut/washer kit
Intake hard Pipe kit $200
Modified to fit 6boost setup
Modified Power steering resevoir relocator for use with hard pipe kit $180
Custome bracket
direct bolt on with charcol canister
Apexi turbo inlet hard pipes $400
for Z32 AFM. comes with plugs and silicon
USED ROH 19" x 10" 3 peice Modena's $2500
Nangkang 275's
4" of dish all round
Shadow crome finish
NEW ROH 19" x 10" 3 peice Modena's $2700
NEW Nangkang 275's $800
Shadow crome finish
ROH 18" x 10" 3 peice Modena's $3000
Michelin 270 full slicks
3" of dish
Three layer pearl
Used for one day only
Michelin 270 full slicks x 16 $150 each
various levels of use
Custom exhaust $1000
75mm x 2 into 90mm into 127mm internal muffler
comes with 75mm x 2 Side pipes for track
New Vbands 75mm x 6 also thrown in(not fitted) but for quick change
Greddy Copy Plenum $500
with silicon 80mm-100mm adaptor
Nismo Plarque
Nismo Gmax Twin Plate clucth $1000
Nismo Flywheel
Pull type
50% life left
Can be repucked when the time comes by NPC for $400(both plates)
Nismo Gmax Twin Plate $900
Nismo Flywheel
Push Type
50% life
R33 GTR Series 3 Vspec gearbox $1000
with redline oil (70,000km)
R32 GTR Gearbox $800
may have short ratio's, will have to check
Normal oil
45,000km
with tranfer case
Field Boxer II linear Torque split controller $800
Known, best for track
Greddy Profec B boost controller $400
The Good one (3 knobs, no display)
Very very stable boost
Apexi Power FC $1100
with Commander
with Boost control kit
Innovate Motorsports LM2 OBD2 O2 Wideband $500
Stainless tail pipe sniffer
Ohlins Mines Esta Street Edition Suspension $1500
A comfortable ride was achieved at a high dimension with sport quality and balance while regular street driving by adopting the OHLINS shock absorber and the original springs.
In addition to the original specification, the shock absorber has a C ring height-adjustment function and the 20 steps of damping force-control. You can apply your favorite settings.
It gives you the decent driving experience which does not have the sense of incongruity as other types of cars by using the normal spring form and adopting variable rate spring for some types of cars.
This product has been developed and assembled by Mine's
Greddy Boost Gauge, Fuel Pressure $400
White face
Electronic with recall and alarm setting
includes Greddy A pillar pod for 33
Fuel system setup $400
twin 044
some speed flow fittings
BTR surge tank
relays
Carbon Fibre Full length cooling panel $250 $150
R33
Has some cracks around radiator bracket holes
Trust front lower lip $350
Series 3 N1 Bumper $550
N1 reo $250
Series 3 spoiler with boot $800
Front Guards with clear indicators $1000
Side Skirts $370
GTR 001 (GTR WON) Number plates forsale
SA
No Annual Fee
$500ono
RB30 Howards Ultimate forged connecting rods $1000
Guaranteed to 2000hp
The pinical of high hp rods
Piston Crown squirters
3000km's old
Perfect condition
Balanced by PM Engines
Provent 200 catch can $100
awesome item
Alloy radiator $180
R33 GTR shell
All R33 1998 GTR series 3 standard parts available aswell
Matt
Hi,Matt
Very interested in full length cooling panel and trust lower front lip,condition?Do you have the S3 OEM lower front lip as well? please call/sms Alex 0433878905 Melbourne
Thanks
On Night Shift for 5 days now... :geek:
Will get as much parts posted off as soon as I can. Will look at taking a day off again soon.
Matt
PS thanks for all your kind words, sorry for some delays in postage...I work silly hours.
Yes leather and will fit 33gtst but have been sold
My plastic bit has no scratches but has a crack at the back
Series3 finish will post pic
M
Provent gone? (sorry, too many pages to search and check)
If not, ill take it. (maybe you'll send it for $100 total :)
Cheers
Mick
Sorry Mick I went in a package deal.
interested in the other s3 gearbox u have with the redline oil
is this the gearbox u were making 500kw with? if not what is the history of it? condition of the bearings and synchros etc?
also interested in the fuel pressure and boost gauge combo, let me know if u can do both of these as a package deal, i can organise TOLL to come and collect to make ur life abit easier
cheers
oz
cheers
oz
Yes this was the one fitted to the car. There were no abnormal noises and no syncro problems. It has been in the car for 6months or so. Had completed 70k before I got it and minimal since. Would be due for a oil freshen up in the next 12 months.
I can do the box, and gauges,pod&sensors for $1200.
Also have Gmax twin plate clutch available.
Matt
Shell Available now. $5,000 firm
April 1998 Series 3 GTR VSPEC
zero rust
registered, no defects
Plates GTR 001 included!
Inlcuded
All panels, side skirts front bar, lip, grill,indicators rear S3 spoiler
rear diff complete with 4WD system
front and rear has adj camber
looms
A/C compressor, A/C condensor
PS pump
PS rack
All glass
Carpet
Hubs
Adj castor rods
mirrors
rear lights
Window switches
Dash with passenger Airbag
much more
no seats or door trim
no brakes
no motor or trans
no gauges
No head lights
no steering wheel
no intercooler
can supply gearbox for extra cost.
please get in quick if your keen it will go fast.
Matt
PM or 0413023669
zero rust
Inlcuded
looms
PS pump
PS rack
All glass
Carpet
Hubs
Adj castor rods
mirrors
rear lights
Window switches
much more
no brakes
no motor or trans
no gauges
No head lights
no steering wheel
no intercooler
Matt
PM or 0413023669
Shell also has
DLS rear speakers
Jaycar from splits
Sony 504X amp(mounted neat and wired up)
Shell also has
DLS rear speakers
Jaycar from splits
Shell Sold Deposit Taken
33 GTR Gearbox gone with shell
Matt
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
