just wondering what that horrid sound is at high rpm. from about 6000rpm onward (around the same time the engine starts coming down from its power peak) , the engine no longer makes a nice purring sound but instead sounds like its rattling. like v-tec or something kicks in lol. valve bounce??? no its not my coils
https://www.sau.com.au/forums/topic/369678-ugly-sound-at-high-rpm/
r32gtst
big turbo 15psi
fmic
injectors
ems
exhaust
supersparks
Is EmS engine management system :unsure:
pinging off its head...haha...
dont bother fixing it you probably f**ked it already
I dont know what vtec you have driven but mine sounds f**king awesome when it kicks in..highly tuned and finely balanced engine on 8000+ revs, since when does that sound bad..
dont think its the exhaust gasket. i had that before and its like a tractor, mostly heard at low rpms
could be ping but its unlikely. i adjusted the timing too far a couple times and i quickly figured out what it sounds like.
i guess ill try backing off bost and then backing off timing to see if its any of those
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
