just wondering what that horrid sound is at high rpm. from about 6000rpm onward (around the same time the engine starts coming down from its power peak) , the engine no longer makes a nice purring sound but instead sounds like its rattling. like v-tec or something kicks in lol. valve bounce??? no its not my coils
https://www.sau.com.au/forums/topic/369678-ugly-sound-at-high-rpm/
r32gtst
big turbo 15psi
fmic
injectors
ems
exhaust
supersparks
Is EmS engine management system :unsure:
pinging off its head...haha...
dont bother fixing it you probably f**ked it already
I dont know what vtec you have driven but mine sounds f**king awesome when it kicks in..highly tuned and finely balanced engine on 8000+ revs, since when does that sound bad..
dont think its the exhaust gasket. i had that before and its like a tractor, mostly heard at low rpms
could be ping but its unlikely. i adjusted the timing too far a couple times and i quickly figured out what it sounds like.
i guess ill try backing off bost and then backing off timing to see if its any of those
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
