  • Replies 61
Yeah problem is there are only like 3 regular posters on SAU who own V35 - you, me and Geoff (and he lives in Nuriootpa).
I do see some other V35 owners in SA posting in other sections (BPV35).
But I do know 2 people who own nice coupe's that I could personally invite along - and I am sure Munro would bring his S3 R35GTR out to say hi.
And you might like this little mod I did on the V35 today!
Just putting it out there -
If any V Series peeps in SA would like to catch up for a Coffee,Cruise maybe a Feed ...?
Let me know and i will organise something, it would be nice to talk some shop and get some ideas.
Cheers :thumbsup:
Yep, sounds good.
Also had contact with Nick on here in SA.
About to head off with the family for a holiday for 2 weeks if you can wait till then.
Cheers
ok.... Saturday 30th of July - Keep it free, V Series SA Gathering. :3some:
I will have all the details sorted by Sunday (I hope).
If your keen let me know i will start a list of peeps attending, and PM yall the details.
Would be great to see you all there. :thumbsup:
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
