  • Replies 46
Posted Images
It's sold out already :(
FYI You can buy it from Canada for CAD$350, which at the current exchange rate is about $340. Or from the US for US$300, which is $280 at the current exchange rate. All you'll need is a plug adapter, because it comes with a power supply that's rated for 100V-240V input.
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-5905878
For all of u chasing one I am about to sell my whole setup to fund the 34 build, it includes G27, games, desk, bride copy etc etc... I love the setup but after 12mths I miss my car too :/ PM me for details
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-5917302
  • 4 months later...
correct Dezz i had mine mounted to a coffee table for a few months but it was just never quiet right
i don't use it atm but i still have it :D i paid less than $300 for mine
edit and that deal isnt on with ebay but you can get it at the logitech shop
g27wheel.jpg<<Click
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-6147956
You can make a surprisingly good cockpit from a $10 saw horse from bunnings. Chop one side of the legs about 50 mil, attatch a small length of board for the shifter and add some weight to the friont legs for stability, I use 10 kg weights either side. And the more comfy your lounge is the better.
Once you use a G27 you never want to use a controller again.
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-6159841
Not the prettiest cockpit but I seriously doubt anything could be more comfy, and totally natural driving position.
The important thing is using the weights to stabilize it, where the tape is on the legs is where i put them and it makes it completely stable
even with the power of the G27 motor.
299 is a steal I paid 499 from dicks in January this year.
post-53444-0-80343100-1324379184_thumb.jpg post-53444-0-73997600-1324379125_thumb.jpg
Edited by NISMATT
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-6159943
You could always go to a wrecker and pick up a Commodore Executive seat for next to nothing, mount it on a board and attach the hobby horse to it. No need for weights and you have a vertical adjustment for height and rails for length to suit different people. Takes up more room though.
https://www.sau.com.au/forums/topic/370119-logitech-g27/#findComment-6161724
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
