Hey guys,
Over the last couple of weeks, my beloved 33 started to develope a missfire, however not during boost, but when on idle (sounded like a rexxy, vibration through the car and lack in power).
Weird thing was, when engine braking it was running fine, yet under throttle is when it runs like s**t. So i decided to give the car a service, oil and filter change, spark plugs replaced, Injector cleaner added to fuel, new air filter, fuel filter, diff oil, gearbox oil and 2 new tyres on the front. However, the constant missfire persists, and yet there a splitfires in her...??
Other thing is, ive noticed a slight moan on idle, but when revved, sounds fine? Could be related?
Much thanks to anyone who can help me out here, much needed.
the usual things to check would be ignitor pack (its a series 2 so you wouldnt have one of these), CAS and AFM.
open the AFM up by carefully removing the rubber seal around the cap with a razor and re-solder all of the connections inside. use gasket maker to re-seal the cap.
try swap over a CAS with a known working one, you must keep in mind that timing will be effected so you will need a timing light to get it back to 15deg on idle.
  • 3 weeks later...
Thanks guys for the info. Been tied down at work so only just got back round to the car again.
I checked the ecu and got fault code 21 - ignition signal. Ive changed my plugs 2 months ago.
I'd say it be the coilpacks but they are splitfires. Not saying these can't s**t themselves too.
Any other ideas?
New information!
It will only do it while the car is warning up. As in between "C" and normal operating temperature. Turning the car off and back on usually fixes it. But only when warm
Any other ideas guys? It seems to happen moreso when it's less than half a tank full. Which seems just weird
hasnt happened since tank has been filled, dont think it could be fuel related...?
what you did with the AFM will only prove that the car doesnt work properly without it connected, and idles fine when it is. its got nothing to do with how it works under load.
could be a split fuel hose at the fuel pump or could be the actual fuel pump.
Edited by SECURITY
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
