Hey I'm looking at putting some 6 by 9s in the parcel tray of my car and after much searching I believe I've found how to move the rear seat out of the way. but what i was wondering is are the rear speakers are 6 by 9? or if they are 6's? and then what am I going to need to do if I want to change them to 6 by 9's?
Cheers in advance guys!
https://www.sau.com.au/forums/topic/370595-r33-rear-speakers/
6x9's wont fit unless you use a spacer type thing.
I only have 6x9s in mine because i had them. So got some black plastic spacers to lift them enough to fit.
Easiest option however is 6.5inches. They just dont have much nuts to them.
Right, so 6's is the general consensus? other than the installing problem im not to sure what the problems are with the 6x9s though? anyone then have some suggestions on the type of speakers to go for, is branding etc merely going to be personal preference
here is a few reasons they suck
1) Possible standing waves in the surround.
2) Non-even dispersion of sound wave across
radiating area
3) Standing waves IN the cone
4) Poorly controlled moving mass due to
unsymmetrical loading of suspension.
when you ask what brand 6 in to buy it depends on budget, tastes, brand loyalty and so much more , and if you have amp or factory deck etc to power them ?
and of course then if you don't install them right any speaker will sound horrible, or out of phase , no bass etc.
dont overlook some of the SAU sponsors or contributuors on here ?
yeah but what i meant was if the 2nd pic is a 6inch speaker - and he is saying that 6inches is the biggest that will fit the STANDARD speaker mounts - then why is there the piece of mdf? (sorry dont mean to argue such a small point, im doing my system soon - just wanting to confirm the sizes without having to cut/fabricate anything.. was told and have read they are 6.5 front and rear but possibly they arent?)
Im not sure what the issue with 6x9's is either.
When i had them in the parcel shelf of my ITR they sounded fantastic. Possibly because i did a good job installing them properly.
They sound like ass, and i knew they would, in the 33 because they dont fit. But it was a remedy to have sound, rather than broken speakers.
Sweet went for the 6" got some nice clean crisp sound going on, next step bass =]
I'm running 6.5" component speakers in the front powered by an amp with the rears faded and found the sq and bass was good enough not to require 6x9's or a sub
Whats "sq" sorry? but yer might give that a go first and then if i feel the need to add more i can go from there
  • 2 months later...
Ha well im semi afraid to say I went with the 6x9's but they have worked out well, got an 800w amp powering them and the 6's up front and they sound great and crisp also got a 10" sub powered by just a 222W amp at the moment which goes well but lacks the power at louder volume so upping the amp for that soon
Oh and also just heads up for others, I wired mine so that my front and rear speakers are playing off the front RCA port and the sub is off the Rear RCA port in the headunit. means I dont have a difference between front and rear sound at the moment, but means when I fade all the way to the rear I just get the sub, neat little trick :P will probably end up wiring it back so that front and back are in their respective ports and split the rear port for the sub also
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
