^^ sure does.
Kitchen has a plethora of germs.
* sponge as stated
* chopping board for meat and dairy
* fridge not cold enough
* tea towel
* humans forgetting to wash hands
* tap handles > handles on microwave fridge etc
Ebola reaching USA :-
CDC is in a flap tracking down contacts of an Ebola sufferer who's landed in their midst. Trouble is, the victim had been walking around with symptoms for 4 days before reporting to hospital. :(
Bacterium:-
MDR-TB death in N Qld
MultiDrug Resistant Tuberculosis can spread through being in close proximity to an infected person.
Doctors are struggling with this because traditional antibiotics like Rifampicin and Isoniazid haven't been able to keep pace with TB's mutation.
Stay tuned.
Ebola :-
* unconfirmed report filtering through that one of the afflicted health workers in the USA could only have contracted it through a sneeze or a cough - meaning it's become airborne
* after five meetings in the Australian federal health department, politicians have still decided not to quarantine pssengers flying here from West Africa
* a plane with 152 on board has been forced to land in Madrid due to a passenger from an infected area came down with fever and shaking. Passengers are isolated
f**king retarded health workers...thinking they're doing all the good assisting in undeveloped countries and fking us over here by potentially bringing back diseases. Put yourself in quarantine you arrogant shits, what's another couple weeks away from home.
  • Like 1
  • 7 months later...
Superbugs in Melbourne's hospitals :- I dare say Victoria isn't the only state where hospitals host antibiotic resistant bacteria.
The trouble is, even by sanitising wards from ceilings to floors the bugs still infiltrate and "call the hospitals homes"!!!!
Hey Terry, are humans known to catch anything from Birds other than H5N1?
Got bitten by a cockatoo last weekend and have had some gastrointestinal symptoms since...diarrhea, esophagitis, bed sweats.
Mind you I also had some very spicy Indian the same night and whilst I love spicy food my digestive system doesn't. It doesn't seem to be progressing into anything but am thinking a tetanus shot might have been a good idea after the bite.
Your thoughts?
H5N1 symptoms don't appear to be there from your info Birds.
Symptoms I suspect are from food poisoning. Eat chicken? I can't ask if something tasted off I guess because of strong tastes at that restaurant ay!
I had pork...the menu warned me of the spiciness and this is Indians giving something a warning of being hot! Have had it before though and never got more than a long toilet stay the next day. This has continued for the past few days. Pork is always a good candidate for food poisoning I guess.
The throat symptoms are a bit like when I've had a stomach ulcer before and you have that feeling of reflux burn, like the esophagus feels slightly burnt from the stomach.
Trachea feels okay. I suppose food poisoning could have been responsible and the symptoms do appear to be lessening rather than progressing. Just unusual that I've had no want to throw up like I've had before with food poisoning.
No real fever besides the bed sweats which were bad on first night but have gotten better - only a couple patches lastnight.
Thanks for your consideration!
  • 3 weeks later...
  • 1 month later...
I recently had a fungal infection on my scrotum *gasp*, clamatazole and tolnaftate seems to help but the creams wear off with time when with clothes on, so the treatment wasn't successful (two tubes of each). Acetone, the paint grade, works so well. The next day after applying once on my balls with cotton balls in the morning and once in the evening, the itch is gone. No more lychee balls. Balls.
For skin fungal infection, what would you recommend Terry? Acetone seems like a sledgehammer solution (even though it worked), and it is not pleseant on the skin, especially cut skin from scratching an itch, in the nether regions.
Fungal Candida infections there usually come from the inside rather than through intercourse when men are affected. Do you get also...
* bloated tummy or wind
* foggy thinking
* blocked sinuses
* constipation or loose motions
* bruise easily with minor bumps
* breath goes off despite good dental hygiene
* crotch itch as well
??? Any 3 of the above???
I think all except for the bloated tummy, stool issues, and being easily bruised. My blocked sinuses could be the cause of the bad breath *gasp*. Thank you for your time in this, could I have a candida problem? Yesterday was my regular checkup, but this was not mentioned. I am not in grave danger am I?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
