Hi all , I've seen the question asked often about chamber and piston volume differences in R33 and R34 RB25DET engines .
From reading about engines in the late 90s I know there was a push for LEV or low emission cars and ULEV for ultra low emissions approaching the 00s or naughties . Mechanically I think it involved differences in power steering pumps and belt drives and possibly lower drag alternators . Often VCT and valve timing changed and engine management was set up differently particularly for cold starting . By that stage most engines already had cooling systems with bi level thermostats and big bypasses to help them warm up quickly .
I just ran a couple of searches to try and find out more about specific chamber and piston volumes in the R34 Neo RB25DET but couldn't find anything conclusive ie pics and exact measurements .
Wiki reckons the chambers are different , smaller , and Nissan compensated with RB26 spec connecting rods which sounds odd . To have a piston further down the bore at top dead center doesn't sound like a positive to me , dunno .
I did find a thread at an American site where a fella tried using an RB26 crank in a 25 block with 25 pistons and not surprisingly the pistons ran proud of the blocks deck . Should have seen that one comming .
The thing is this fella eventually mentions a difference in chamber volume from 33 to 34 as being 63cc and 51.5cc .
It would be really good if someones whos been inside a stock standard RB25 Neo can tell us what they actually have in the chambers/in the piston crowns/if the rods are different length wise .
Assuming the chambers are smaller ie 51.5cc it starts to make the cheap RB30 conversion look good and may even get the static CR up around 9.5 instead of the 8.2 or whatever you get with an R33 head on an NA RB30 short block .
Anyone know the real story ?
A .
This is from a piston supplier:
The Neo head is 51cc & the normal rb25 head is 62.5cc
I believe the block for the neo is the same as for the R33 block but that's not based on actual observation.
And to add to Disco's questions
Are the conrod lengths the same
Are the pistons the same
ie either a lower gudgeon pin height in the piston or a shorter conrod? or are they the same and the squish area is 18.4% less ie much closer tolerances?
If they were the same then you wouldn't get:
yes you would, the 26 crank has a longer stroke than the 25, hence simply having a 26 crank in a 25 block with 25 everything else doesnt work.
not 100% sure but from what i've seen on here over the years the rods are all the same length (all rb25 and 26s), with the neo getting the stronger (but not longer) 26 rods. the neo has a smaller chamber with a different piston design to allow for it, which was probably a better squish design, hence why getting aftermarket neo pistons in the right compression ratio isnt always easy.
OK, thanks Jonno, explained.
So in essence the head volume is less but the piston shape negates this, so the final piston/chamber combo volume at TDC may well be the same.
Ok , so how much more do I want .
I wanted to know the details in case there was anything people can work to their advantage .
If I was going to do an RB25 head again I would go with a Neo one because of its smaller chambers and non hydraulic buckets . Really anything that potentially has better quench and resists detonation is worth having , Nissan must have had good reason to make these changes and it looks like emissions/consumption reasons to me .
A .
Well, in that case you don't want to go digging through aftermarket piston catalogues looking for things that are pretty much not there. You just need to get an old RB25 piston and a Neo piston in hand and see that they are different and where they are different (which is pretty much crown height and shape), realise that you most likely can't really mix and match with anything else that'sout there in RB25 aftermarket land and just go get some CPs or Arias or whatever floats your boat custom made like everyone else who has had to do so. It's either that or use some non-turbo RB25 pistons (possibly with some extra valve relief), remove the turbo and run on E85 or meth or LPG.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
