Hi all, Cut story short, just done a nistune, on my way home, im experiencing (twice) lost power (about milli seconds) and power came on again ... One, when i was on the freeway did normal speed 100 k's and tried over take someone and then power lost or boost drop or maybe boost spike idk... Then second time, floored it then it happened again?? Im bout to talk to the tuner tomorrow, but i just want to knw wat it is?? Its set up 13 psi on a stock turbz , stock inj... Mods are ; full exhaust, pod , ebc controller , fmic and walbro fuel pump...maybe its not liking the 13 psi ?? Should bring it down to 11-12 psi?? Im only getting 194 rwkw @ 13 psi with a lot of tourqe..
Edited by myRB25DETT
https://www.sau.com.au/forums/topic/370782-just-done-nistune/
  • Replies 45
Sounds like you hit the TP cut (what others call boost cut). Running that much boost will pull enough air flow through the AFM for the ECU to freak out. Nistune allows you to push the cut point up higher, but your tuner may not have done so.
By the way, I agree that 13 psi is risky on an RB25 turbo.
But this tuner is a well known tuner here, id think he knows wats hes up to...car is a weekend only, and dont see any tracks, daily car... Anyways i will talk to him tomorrow..
Well all i know is my mates R34 GT-T manual made 209kw on 10psi with pod,zaust,fmic and stock ecu.i don't know shit about aftermarket tunes but your tune sounds funky on many levels.
Edited by Blueone
I agree with everyone 13 psi is way to high ur turbo wont last long
I dosed my previous 25 on 0.98bar for 6 months and nothing happened. but alas someone had to write my car off,so the effects never showed themselves lol.
That sound (as already written) like TP-Cut.
TP is the load the ECU calculates, if that's over a certain limit the ECU cuts fuel/ignition.
If you had your car tuned, the tuner should have taken care of this (so probably a different issue?)
194KW sounds about right.
Can you post your dyno?
Cheers ..
Cheers ..
Im not questioning his ability, i guess its my fault as i was rushing it a bit as well and asking impossible figure originally, i will post result tomorrow or shall i say later as its already 1.00 am...
I take it all back since I did not realize that we were talking R34GTT ..
I compared the figures to my R33 GTST!
Edited by Torques
My stock R33 series 1 RB25DET made 188rwkw on 10psi with pod,zaust,fmic,exhaust leak behind turbo and avcr with stock ecu. that figure for 13psi sounds a bit on the shit side of life.
Not really, his result is nice and realistic, it is your result thats a little inflated. Which is normal for some dynos as there is a 10/15 variance easily enough.
Stock RB25 turbos are only good for ~200rwkw @ 11-12psi
I was gonna say...
Maybe so but i still think that is a bit much boost for that power with a modified tune.
My R34 (Tuned by Toshi) running around 12psi, front mount, zorst,walbro (according to psi dyno reading taken from intake plenum) made 195rwkw. My EBC (greddy profec B spec II) reading peaked at 13 but then drops off to about 10.5psi at around 6000rpm. I have about a 1psi diff in boost reading from EBC to boost gauge :-(
Been running between 12-13psi for a year now, no signs of giving way yet, but then again, I use low boost setting alot more than high boost
194rwkw seems about right
But mine is getting boost cut!!! Does urs??
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
