My new engine is the devil, 25/30 with 1 mm restrictors, opened up drains, return lines from the back of the head, catch can with return line, Tomei pump, bigger sump with windage tray.
Every track day the catch can fills with oil and sprays everywhere, the pump has been adjusted to lower pressure, extra drains in the top of the covers, its slightly less than it was but still spat 2 ltrs after 3 warm up laps and 1 hot lap. Im going mad with this.
Sump holds about 7 ltrs of oil and dip stick reading is at the top of the hatching when I go out and it was half way down it after the 4 laps.
Comp is good as is leak down.
Limited to 7200, balanced, 18 lb 310kw.
Is my only other option a scavenger pump from the head to the sump ????
1. Have we missed something in the build.
2.To much oil in the sump causing trouble.
3. Needs scavenger Pump.
Any ideas are most welcome.
Stevo if you see this whats your pump and stuff, Ill be PM you about it anyway if you dont see this thread.
Some pics.
https://www.sau.com.au/forums/topic/370836-oil-overfilling-catch-can/
Where does the back of head line goto? Goes into the sump on the inlet side and into the turbo oil drain on the hot side
You need a breather line from the inlet side of sump to your catch can. the return from the head to the sump on the inlet side has a tee which is connected to the front of the sump and the tee going to the catch can
Thanks mate.
Interesting. All that done and it still spews oil out.
What size is the inlet side of sump to your catch can from the tee piece?
The only other thing I can think of that might be causing the issue is the breather can filter size. It looks way too small. It also appears to be the only one on the can, there isnt a second one hiding somewhere?
What sort of leak down were you getting too?
What size is the inlet side of sump to your catch can from the tee piece? 3/4"
The only other thing I can think of that might be causing the issue is the breather can filter size. It looks way too small. It also appears to be the only one on the can, there isnt a second one hiding somewhere? Its a 3/4" outlet to filter which has 6 square inchs of surface area.
What sort of leak down were you getting too? 15, I think, tuner said it was OK for a forged engine running hard rings
Its got baffles behind the vents.
They think its possessed by demons from hell, going to try running slightly less oil, mucking around with the catch can and hoses, maybe redirecting some oil from the pump straight back to the sump, and if none of that works a scavenger pump may be the next option.
All this for a daily driver / occasional weekend track day car
I do need to win LOTTO right about now.
Marks prayer, "Dear JEBUS let me win LOTTO and Ill shout the boys a free track day, AMENS"
Stupid oil doing stupid stuff, FFS, how hard is it..............................
cp pistons? NO
ps. all oil returns to the sump need to be below the windage tray and on passenger side. The return line on the hot side is by using the turbo oil drain point but the cold side goes into the drivers side at the top of the sump, could this be a problem you think ??
Thanks, Mark
How new is the engine build? 15% leak down seems alot if its pretty new.
What pistons and piston to bore clearance if you know?
Does the engine breathe heavy when its warm as in does blowby vapour come out the breather filter normally?
Gets a lot of blow by when cold but when warm its a lot less, tolerance was apparently in spec for the piston and rings used, wisco piston if I'm recalling right.
And yes the motor is new.
hmmm it shouldnt really be breathing heavy at all after its all bed in and running right. Our leak down is always around the 2-3% mark across the board and my road car was about 6-7% before I started my new build.
Unless its something silly like an out of round bore or too tight in piston to bore and its grabbing slightly. You shouldnt have so much blow by and oil spewing, especially with all the mods you've done.
Will be blocking the middle restrictor in a couple of weeks, so only a 1mm at the rear and the 1mm at the VCT, the TOMEI pump pumps coupious amounts of oil, we will see if the lifters like that if not then may need to go solids, will hit the track ASAP after fix and post results, as for the leak down Ive been told for a forged engine with the rings that have been used (hard ?) that 15% is OK by as many people that say its not, LOL.
A guage was put where the dip stick goes and at WOT there was not a significant amount of pressure in the sump.
I suppose every engine is different in its own way, it goes like the powers of piss, I just need the oil to stay where its meant to.
On a side note my syncros came out the drain hole when I changed the oil in the gearbox for some Redline, not sure if the Redline will mask the damage anymore, LOL.
Fingers crossed.
Mark
we had a pretty breath heavy rb30 at work. (1,2,3 15-20% leakage 4,5,6 10-15%) it had the oil drains going to the drivers side front of the sump. oil came UP the drain hole on the dyno... if anything id leave the passenger side drain and block the drivers one and see how you go.
lol yeh the blowby would have been carrying oil up that line to head.
Maybe just block off the Tee joint and leave the line going from sump to catch can. Get rid of that half of the back of the head drain/vent thats going to that Tee joint on the inlet side.
How much hard/high load running has the thing actually done?
And what spec oil has it run (and currently running)?
Sounds like there may well be issues in bedding those rings properly yet. Different experiences for different builds, but it appears that chrome rings aren't always easy to achieve a good bedding until the engine has had plenty of work. Also don't make the move to full synthetic engine oil too quickly - it will work against you getting rings bedded. That's something well documented in motorcycling circles.
The earlier comment regarding filters on your catch can are close to the mark too. There might be lots of filter area, but have a look at the total cross sectional area in the hoses running from the cam covers, and compare it to the size of the nipple your catch can filter is mounted to. It is reducing, effectively makes a venturi so the air velocity increases as it is pushed out of the catch can. Give some thought to redesigning your catch can for internal baffling, and at least another filter.
Heavy breathing is fairly common but doesn't seem to be much talked about as there are so many different approaches to sorting it. And you probably won't see the issue raise its head in thousands of road km because you can't drive hard enough, long enough to create the same conditions.
FWIW I've seen Subarus spit 1 litre (and more) in 3 laps of the Morgan Park "A" track (pretty short circuit). Another mate has told me of an engine that took an entire season of racing for his heavy engine breathing to resolve itself as the rings finally bedded.
10W-40, The motor has done maybe 2000k of road use, and only about 12 laps at Wakefield 3 sessions of 4 laps super spints and 6 laps of Eastern Creek (but in the wet), so not even getting hot, catch can is being redesigned as more of a oil air seperator style of thing and restricors are being changed to a 1 mm at the rear (whats in there now) and blocking the middle one (has a 1mm in here), the VCT drain is being reconnected and the drains are being rerouted to the left hand side of the sump(VCT has a 1mm restrictor).
Hopefully that fixes the problem, if the lifters get noisey the spring will go back in the Tomei pump to give it some more oil as it was removed to try and stop the oil surge before but that was unsuccessfull.
Goes in again tomorrow for the next week or so.
So with a new TO4Z, recoed gear box, new clutch and the oil under control I may be able to get some fun hot laps in with the new motor, finally.
Hopefully.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
